Converter for 87 Iroc; 3000 too big?!?!
Old 06-05-2004, 12:00 AM
BriancWS6's Avatar
Default Converter for 87 Iroc; 3000 too big?!?!
I have a buddy with a 87 Iroc that is wanting a higher stall in his car, he says everyone is telling him that 2500 is as big as he needs but I called BS. I am in the middle of installing a 3500 in my car which he thinks is a bit too big. I told him to not be a ***** and at least get a 3000. What do yall think about stalls for this application. Thanks in advance.
Old 06-05-2004, 03:40 AM
ssvincels1's Avatar
those tpi motors do not like to rev, they run out of steam pretty quick
2500 would prob. be good
Old 06-05-2004, 10:36 AM
Crazyquik's Avatar
Different engines with different characteristics need different converters.
As already mentioned, the LS1 which loves a converter is a different animal than the TPI. While 3500 isn't uncommon for an LS1, it would be way to high for a mainly street car TPI. I'm not sure if 3000 is too high, but I wouldn't go much higher.
I daily drive on a ~4200 in an LS1.
Old 06-05-2004, 10:42 AM
86 IROC's Avatar
What is done to the car? The old motor that was in my 86' - 350 tpi, small cam, all bolt ons, liked a 3000-3200 stall the best. I tried 3 different converters before settling on the 3000-3200. I ran 13.00's on BFG drags, full weight - no weight reduction, and pulled low 1.7 60' times. HTH
Old 06-05-2004, 11:25 AM
Kurt D's Avatar
Power makes a diffence in stall to; what does a old IROC 350 put out? 250 hp? What does a typical LS1 put out? 350 hp? What stalls at 2500 in his car may stall at 3000+ in a LS1 (assuming you could swap them directly). Hence the drivability issue people warned him about. His converter would need to be looser to stall up to 3000; thus feeling looser for everyday driving.
Oh yeah, idealy you want to choose a stall close to peak tq. Where is that at in a stock TPI? I'm sure it's not much more than 3K if that. Of course a cam would probably move that up.
Old 06-05-2004, 11:34 AM
Just Floor It's Avatar
Like the other guys are saying.....What mods does he have?? Cam and gears would make a difference... For a huge difference you should tell him him to get an aftermarket intake....They'll rev to a little over 6k... With an intake you should be able to run a 3k stall....
Old 06-05-2004, 12:07 PM
BriancWS6's Avatar
he has 4.10 gears, flowmaster, no cats, and K&N filters, thats about it. 2500 may be about right for his car, but I wouldn't go any lower in my pinion.
Old 06-05-2004, 01:20 PM
86 IROC's Avatar
4.10's? I'll assume it's not a TPI car then. Is it even a 350 in the car?
Old 06-07-2004, 02:46 PM
BriancWS6's Avatar
Whats wrong with having 4.10s in a TPI car? And yes it is a 350. I don't get what you meant with your above quote. Of course the gears aren't the stock ones, he put them in.
Old 06-07-2004, 03:33 PM
Moderator
jimmyblue's Avatar
If he has full torque up to 5500+ RPM then
a 3K stall is not too much. With a stock late
'80s cam & heads, though, he's likely not so
strong up top. But that can all be fixed too.
What really makes a higher stall livable, is
the lockup clutch and an overdrive tranny.
But a 4000RPM stall and a 5000RPM powerband
would be a little bit mismatched.
Old 06-07-2004, 03:45 PM
BriancWS6's Avatar
He called me earlier and has already order up a 2500. Thanks for everyones feedback.
Old 06-07-2004, 04:32 PM
86 IROC's Avatar
Too much gear for a motor that peaks around 4600 RPM or less w/ the stock cam. I tried 3.42's & 3.73's in my own car that had a small cam, and it liked the stock 3.23's best. 4.10's in a tpi car would be like 5.13's in a stock LS1 w/ 26" tall tires. Great for 1/8 mile maybe, but not much else.
