Yank SS4000 vs SS4000E what's the diff?
Like the title says I have the SS4000 and bought it when it came out now I see the 4000E converter, what's the diff?
-Sly
-Sly
From what Mike told me the only difference now between the SS series and the SSE series is that the SS has 3 lugs while the SSE have 6 lugs, internally they are identical.
Originally Posted by slyws6
gotcha ok just wasn't sure if I needed to upgrade while I have the engine out. Thanks.
-Sly
-Sly
I have the E series and ran a friend with a PT4000 on the street once upon a time and he has dyno'd more then me and I was right next to him -- I don't have any dyno's with 4000E though
Location: sojourning....looking for my city whose builder and maker is God.
-Sly
-Sly
I don't think I'll be changing it out, dont really want to spend the money, already spent enough on this buildup I'll just stick with the SS4000 for awhile. If I ever do change it out you'll be the first to know
-Sly
-Sly
-Sly
-Sly
Well like I said I talked with Mike when I bought the SS3600 and that's what he told me. I was going to order an SS4000E, he suggested the SS3800 instead and said the internals are identical. Apparently at one time they were different but now they're the same.
Originally Posted by CamaroSS_2002
No they are different, the E series is a multi-disc design, it will handle a power-adder more efficiently than a non E series. It also has the posi-lockup clutch -- they are totally different.
The SS will be a tighter stall ,but if you are considering a 4000 stall anyhow you won't be disappointed in the PT series explosiveness, tire will be a must. The SS series for a daily driver is about perfect though .
From Yanks Website.
SUPER STOCK 3600/3800 (245mm very high stall torque ratio due to 21 blade stator, hard hitting launch, 3600, 3800 stall, 2.50, 2.55 STR) LT-1, LS-1: $895 photo
SUPER STOCK 4000 EXTREME (245mm, Yank's top converter for running N/A or with power adder, 21 blade stator, Posi Lock-Up Clutch w/Kevlar Linings, 6 bolt mounting lugs, lightweight billet cover, 4000 stall, 2.60 STR) LT-1, LS-1: $995 photo
http://www.converter.cc/general_motors.htm
You trying to say he's basically telling you he charges $100 for 6-bolt mounting lugs?
Look at his converter chart http://www.converter.cc/converter_choice_guide.htm
Man I'm not going to argue with you, I was simply stating what Mike told me that's all.
If the are the same, why the price difference and why does he advertise them differently?
From Yanks Website.
From Yanks Website.
Moderator
From Yanks Website.
From Yanks Website.
Do you remember/know what your converter weighed? Mine weighed in at 31lbs. Weigh it when you get it, that'll be an easy way to tell if they are really different.
Theoretically yours should be a few pounds lighter if all he does is add bolting lugs to the hub.
ANY "E" Yank converter has 6-bolt mounting lugs and a posi-loc clutch with kevlar linings. You're getting alot for your money if you need these things. For NA performance these things will not help unless you're making a tremendous amount of power.
