O2 went bad AGAIN-help!
I installed Hooker LT's and a Hooker ORY on my car at about 5k miles. At 11k, the driver's side 02 sensor went bad, so I replaced it with another AC Delco. At 39k miles, that one went out, so once again I installed a new Delco. It lasted under 3k miles, and is now throwing FIVE different codes. One is, of course, bad O2 sensor bank one, another is some sort of o2 heater code, the third is a random misfire, and the other two are a 1133 and 1153 ( I was told they had to do with the O2 sensor also). Is there any reason I went through that one that quickly, and any reason for 5 codes? Also, is it normal to have to replace one three times in about 40k miles? The passenger side is the factory original, and has never gone out.
TIA!!
Tarah
TIA!!
Tarah
Nope, local shop never got around to scheduling me, so I gave up. I know it's got ignition probs, as you can see on the dyno graph- this is with about 6k on the car, 1k on the headers etc...And again, over 40k on the pass. side with no probs, but 3 gone bad on the driver side.
Moderator
With both headers and an oddball MAF on there,
you really want tuning. I don't see how those
graphs indicate an ignition problem. Fueling is a
more likely bet.
I think you've got neighbors on here, might find
someone in the Triangle who's willing to help you
out with logging or maybe even get the tune
straight. If you're tuned clean the sensors will
work longer without fouling. I think I've even seen
a Carolina Auto Masters dude (or one of 'em) post,
like the shop on your dyno sheet.
more likely bet.
TIA!!
Tarah
TIA!!
Tarah
The first O2 that went out felt that way, but the other 2 times it has been unnoticeable. It was driving fine, then the SES light came on and was steady. This last time it was steady, and flashed for a few seconds one time a few days after the SES light came on, but not since then. Someone said that it may be rich/lean on bank 1, causing only that one to go bad. Any other suggestions?
I've been thru 3 O2 sensors on the driver's side, 2 on the passenger since going with LT and ORY Pretty much same codes as yours I've had the bird tuned/LS1 Edit I'll probably jinx myself by saying this, but haven't had to replace in a while
