This is what having a spool in a daily driver does!
Old 07-22-2004, 05:28 PM
SUX2BU's Avatar
Default This is what having a spool in a daily driver does!
My company parking lot is covered with these marks. you know its me cause there is two big fat marks and right beside them is two skinny little marks.
here is the culprit
Old 07-23-2004, 10:14 AM
BigPlanTransAm's Avatar
what are the skinny marks from? are you plowing your front tires?
Old 07-23-2004, 10:35 AM
JeffT's Avatar
yes. Since the spool keeps both rear tires turning the same speed during a turn it causes the frontend to push. It's most noticable during tight slow turns such as in the parking lot.
Old 07-23-2004, 10:40 AM
IrateTA's Avatar
haha, that's too funny
Old 07-23-2004, 10:46 AM
Moderator
xp3nd4bl3's Avatar
Spools + Parking Lots =
Spools + Dragstrips =
I despise my spool every day, except race days.
Old 07-23-2004, 10:48 AM
Race your car!
JL ws-6's Avatar
It must be fun when the roads are damp................
Old 07-23-2004, 10:51 AM
chpmnsws6's Avatar
same with my locker
Old 07-23-2004, 11:14 AM
CHRISPY's Avatar
You should have seen me trying to park on a cruise night last wed
It was pretty funny, tires screeching, skinnies pushing, 8 point turn LOL!
Old 07-23-2004, 11:29 AM
fastsspr's Avatar
What was your experience in wet road conditions it is unsafe???
Old 07-23-2004, 01:18 PM
OWENMUSTANG's Avatar
thats got to play hell with tire life!
Old 07-23-2004, 01:39 PM
SUX2BU's Avatar
actually its not bad at all. this thread was meant to be a joke. this is the worst part of having a spool, but to me its nothing. i've driven in the rain ALOT and as long as you drive like its raining outside your cool.
Old 07-23-2004, 01:45 PM
CHRISPY's Avatar
I have NO problems with the spool. I actually prefer it to a posi
The only things I watch out for is parking. Dont leave the spool loaded up when you park. Move forward/backward to release the pressure on the axles and then go into your spot.
Old 07-24-2004, 02:36 AM
That's what she said...
TheBlurLS1's Avatar
my rear end is stock and it NEVER EVER only spins one tire. when it was on the lift, i couldnt spin the tires independantly of one another if i tried. is this normal?
Old 09-17-2004, 02:40 AM
2MuchRiceMakesMeSick's Avatar
Im still deciding myself spool, posi, or locker. The spool doesnt seem that bad at all. I have heard that it cuts you DR life down alot. Does anyone know how much?
Old 09-17-2004, 09:14 AM
BTL FED's Avatar
It does make a pretty big difference because whenever you turn you are dragging a tire across the concrete
Old 09-17-2004, 04:58 PM
Nova5's Avatar
Originally Posted by ramairstyle00
same with my locker
rat-at-tat-tat-tat..... who installed the machinegun in my differential box?!!
Old 09-18-2004, 12:39 AM
Mean Green z28's Avatar
Don't worry, that's normal if you have a Zexel diff, which you prolly have. It uses worm gears for the locking action and not clutchs like other limited slip diffs. It'll act like an open diff on normal/light torque situations and lock up when more slip is generated. I have the same on mine, and it bugs the hell out of my 'cos it's kinda unnerving when taking off while turning 'cos the rearend is loose until the gears kick in.
Old 09-18-2004, 02:45 AM
Well I went ahead and got the 9" spool. We will see how it works out.
Quick Reply: This is what having a spool in a daily driver does!
