Will bad 02's rob horsepower?
Old 08-24-2004, 07:15 AM
ThackerSS's Avatar
Default Will bad 02's rob horsepower?
How much can a bad 02.. or multiples rob HP?
Can they make a car that is susposed to trap 109+ trap 106?
I know for sure both my front 02's are bad.. and throwing multiple codes a piece.. car doesn't seem to run too terribly bad except it is down on power.. not much.. but enough to tell something isn't right. Car has also only trapped 106 with an m6 car.. and I have almost all of the bolt ons aside from ls6 intake and pulley..
So.. how much HP can bad 02's rob?
can they also cause knock?
Old 08-24-2004, 03:53 PM
ThackerSS's Avatar
bump?
Old 08-24-2004, 04:06 PM
Another_User's Avatar
Probably only if the bad O2s are putting his trims positive and throwing off his af at WOT. I think.
Old 08-24-2004, 04:10 PM
Keenov's Avatar
Not sure about robbing horse power. I have heard that they make your gas mileage suck though.
Did you run 109mph before? You can't just suppose your trap speed, you could have a factory turd
Since you are for sure they are bad, replace them. Then goto the track and let us know the results. I would like to know aswell.
Old 08-24-2004, 05:09 PM
ThackerSS's Avatar
Car made 333rwhp after the headers, it was fine.
333rwhp and trapping 106? Don't believe so.
Old 08-25-2004, 09:33 AM
MyLS1Hauls's Avatar
If they throw off the LTFTs at WOT,then yes it can cause a power loss. I wouldnt expect it to make a huge difference though.
Old 08-25-2004, 11:38 AM
blubyeu2000's Avatar
**** im getting 8 to the gallon, maybe its my o2s
Old 08-25-2004, 11:56 AM
Keenov's Avatar
Dunno, maybe your VTEC didn't kick in
Old 08-25-2004, 02:15 PM
Dal1as's Avatar
Yes, bad O2's will hurt performance and hp. Especially if you're SES light is on (limp mode)
Old 08-25-2004, 07:15 PM
That's definitely another good point.
Old 08-25-2004, 07:17 PM
Cerebrex's Avatar
if the SES light is on, then you are probably losing quite a bit of power
