Exhaust band clamp leaks
How can I get rid of the leaks in my exhaust clamps? Any tighter and I risk rounding or stripping the bolts. I have tried using Aluminum HVAC tape twice and That just made it worse. Should I use some sort of exhaust epoxy? Header wrap? What to do? My car sounds like the joe dirt mobile.
Thanks,
-Tony
Thanks,
-Tony
LS1Tech Administrator
Received 1,493 Likes
In my experiance, band clamps always leak, unless the pipe is offset cut (meaning the cuts that allow the pipe to flex/squeeze at the connection are cut like teeth that fit into each other). Not sure if that makes any sense, but I beleive this is how the stock I-pipe is cut to fit the Y-pipe, and I know for a fact that the SLP catbacks are also cut like this at the I to Y pipe connection.
Other than that, crimping clamps or welding have been the only way I've found to stop leaks for straight pipe fittings. This is why I like ball flanges for the header-to-Y-pipe bond, sure they might not flow as well and cost you some minor hp, but personally I wasn't looking to build a race car so that didn't bother me
Originally Posted by The Alchemist
It would cost $300 to seal your y-pipe.
Kleeborp the Moderator™
https://ls1tech.com/forums/generation-iii-external-engine/204776-ever-wanted-see-pi-thon-firelock.html
Another vote for the Pi-thon...yes, they are expensive, but damn do they look purty
Like it was said, I need to drop my exhaust fairly regularly.
Also, I have searched, and there's not much info other than the aluminum tape fix.
I already have lapped (slip fit) band clamps for the connections to the headers, but I also have a 2.5" butt joint on the d/s so I can wedge a cat in before the x pipe. Both styles of band clamp leak.
I welded up my exhaust to begin with, but theres no way Im going to weld it right up to the headers.
Should I try and squeeze some high temp / exhaust epoxy inside the clamp so it squooshes out when its tightened?
STF Veteran
Band clamps, for the most part, leak. There really isn't anything you can do about it. Personally, I would either do a two bolt ball flange, or something like the pi-thons. Other than that, and I would say you are just going to have to keep trying temporary fixes for a permanent problem. The pi-thons can be purchased to fit slip fit connections as well...
I took and impact wrench to my band clamps, and only 1 out of the three sealed. The other two leak, and it is very annoying.
UNDER PRESSURE MOD
Originally Posted by 99-LS1-SS
Not trying to hijack the thread but, you have a very nice looking TA. I really like those wheels.
I've gotten so many compliments from people who aren't even 'car people'.
As for the clamps, I found one at Jegs that should work with the slipfit connection.
http://www.jegs.com/cgi-bin/ncommerc...16&prmenbr=361
I ordered one since my ypipe / intermediate pipe is leaking. I figured it was a cheaper alternative to the pi-thon.
We'll see what happens.
I already have the Dynomax Slip Fit band clamps manufactured by Walker, purchased from summit. They leak. I am using these on my header collectors. The butt joint band clamp from a local napa also leaks. I have black soot being washed out by the leaking condensation, so I know theyre leaking. The aluminum tape didnt work because the stickyness burned off. I guess ill just have to cruise around sounding like the white-trashmobile.
The only other thing I've heard of doing is using a couple wraps of header wrap...it sucks, but band clamps pretty much all have problems, and it is usually related to the slip fit itself, not the clamps. When I get my new exhaust fabbed up, I'll be steering far clear of band clamps.
I used high temp RTV on mine and they haven't leaked since they were put on last summer. I welded up everything except for the connections to the headers, above the axle, and the rear connection on the I pipe which I also used RTV. This way I can get the exhaust off.
My clamps don't leak. You can find some heavy duty ones out there. I bought one, and you could really tell the difference in quality. Plus it was stainless. The magic of carbon buildup should fill in the gaps eventually...
