Buy headers with or w/o emissions?
Old 09-25-2004, 10:06 PM
Procircuit155's Avatar
Default Buy headers with or w/o emissions?
I am trying to decide wether to get headers with or w/o emissions. I don't have to worry about the car passing inspection or emission testing.
Old 09-26-2004, 06:58 PM
WILWAXU's Avatar
If you don't plan on using the emission stuff, no need to have them.
Old 09-26-2004, 07:03 PM
ss rally red's Avatar
Plus the engine bay looks ALOT cleaner W/O them
Old 09-26-2004, 08:14 PM
LS1LT1's Avatar
Thumbs up
Without
Old 09-26-2004, 08:29 PM
cyphur's Avatar
Originally Posted by LS1LT1
Without
Definitely
Old 09-26-2004, 08:35 PM
LawmanSS's Avatar
I bought my Kooks with the AIR hookups and used block-off plates...this way, if I have to revert to using the emissions equipment, I'll already have the provisions...
Old 09-26-2004, 08:39 PM
Krab's Avatar
If I had to do it all over again, I'd definetely go with the non emission equipped headers. It would make the engine bay look better, and you don't have to worry about those checking those spots incase of an exhaust leak. Less weight too.
T/A Medic's Avatar
doesnt say what state u are from... but in CA u cant have LTs on even if it has cats and passes emissions. u failed the visual with no CARB No. So u will have to swap on stock eq. for smog anyways. Go without. I know of 4 people personally that have their EGR or AIR provisons on headers crack and break off...
AIR/EGR
Old 09-26-2004, 09:07 PM
BriancWS6's Avatar
Definately without, you'll just wind up taking the crap off anyway and having to use blockoff plates. Save yourself the time and trouble now, plus it looks better.
Old 09-26-2004, 09:11 PM
_JB_'s Avatar
Without, because if emisions do come along you have the stock ones to put back on.
Old 09-26-2004, 09:36 PM
99blkt/a's Avatar
what does removing the egr and air systems consist of cuz ive had this same question
Old 09-26-2004, 10:13 PM
cyphur's Avatar
SEARCH GODDAMMIT!!!!!
anyhow....its when you remove your Air Injection Reaction and your Exaust Gas Recirculation systems. pretty much this article will explain everything. i went over and found it on ls1camaro.net.
http://www.ls1camaro.net/sections.ph...ticle&artid=70
won't hurt your cats, before you ask. AIR system just cleans up your exhaust gases to try and clean up emissions during cold starts.
af_187's Avatar
check out the links in JRPs sig for how to's..
it isnt hard removing the crap
Old 09-27-2004, 11:36 PM
Thanks alot guys, i've found the links on how to remove the egr and secondary air. Hopefully with the ORY and Hooker catback i won't have much rasp, I can't stand that. I really dont' care about the exhaust smell w/o running cats.
