Big cam tuning help.....
Hey guys, just looking for a little direction here. I have an 02 WS6, and installed a T-Rex cam in her a few months back. Got it dyno tuned right away, and was happy with it. Only a slight bucking at 75mph at part throttle. WOT was perfect. Installed a ported TB, Maf ends, pulley, and true dual exhaust. The car just progressivly ran worse and worse. Got it retuned, but didnt seem to help much. Car is bucking more and more, at different mph's, but only at part throttle, once again, WOT is fine.
Does this sound like a tuning issue? Just replaced the plugs and wires, and my tuner is thinking it might be a bad coil pack.
Any ideas guys?
Any help is greatly appreciated.
Any ideas guys?
a bad coil pack, haha, thats funny. wellcome to the life of having a racing cam dude, mine has always done it a lil at part throttle and mine was tuned by the people who made the cam. my wot tune is bad *** but it takes a loooooooooong time to tune the part throttle crap on that cam to make it run really good, i have learned to ignore it, just gives me more reason to go wot more often
Thanks for the reply. Yeah, i dealt with it when I first had it tuned. I was expecting a lil compromise on the drivability. Just that I know how it was, and now, its quite a bit worse. I dont know the first lick about tuning, and I am just looking for some info to bring to my tuner, so he can start going in the right direction.
Any ideas guys?
Any ideas guys?
Improperly Ported TBs often cause idle and "just off idle" air control problems. Hopefully you have a Shaner, LPE or other quality piece - not trying to flame anyone...just stating the facts.
Moderator
Take the MAF ends back off, put some descreened
junker ends if you must. Shouldn't make so many
simultaneous changes, especially mixture-bending
ones, withoug having a chance to get their tuning
straight.
You probably will have a very high idle MAP and
some really funny cold idle behavior. That cam is
going to cut your low end VE quite a bit and up
to 2500RPM or so. Leaning out the low temperature
part of the open loop fuel air table should help a lot
with cold driving misbehavior while the VE table
has to be tuned for warmed-up.
straight.
Thanks for all the replies guys! My tuner already swapped the MAF ends out for stockers, and he said it helped a lil bit, but still having issues. As for the TB, it is a Jantzer.
I appreciate the help.
