Who drives in the rain?
O.K guys here the issue. I drive my car back and fourth to work everyday. Lately its been raining a lot and my car has been running like crap. It seems that I'm having some fueling issues dealing with the O2's. When I scanned it B1S1 was pegged out at 11.3mv. What's causing this? Does anybody know? I've checked all the wiring it all looks good I even wrapped my O2 extentions to keep them from getting wet and still I'm having the same problems. Does anybody have a clue about whats going on here.
runs like crap, like a missfire crap, check your wires for chaffing cracks may be arking when wet, 90 percent of the time is the cause of a car running like **** in the rain
Originally Posted by NBM2001Z28
it was an 02 for mine, felt ike i was running on like 100 hp.... the connection for the extensions are probably wet. did you put any grease in them?
Originally Posted by ruck98
My Car Dosent Realy Run Like Crap But Say Im Going About 50mph It Like Something Is Holding It Back
Originally Posted by Keenov
What O2 extensions are they? Ones that came with the headers? Or ones that you bought that just connect straight up?
My car is a daily driver, so it sees all sorts of weather and it does not have any problems.
Do I need to get rid of them?
Originally Posted by Phoenix57
all the time and no problems, but then again im stock for now.
The hesitation and sputtering makes you think that its in the plugs, but its not.
This is an interesting issue. Is it suggested to use di-electrical grease when installing o2 extensions? I'm about to install headers in a few weeks and will definitely do so if thats the case, my t/a is my only mode of transportation.
How about another theroy. Long Tube headers transfer heat much better than stock manifolds. Now throw some water on them.... exhaust gas temperatures go down and effectively put the o2's to sleep? A logging scanner is what you need. I have LT's and its a daily driver. No issues with driving in the rain. Fairly fresh o2's up front, and brand new Bosh units in the rear.
GM has another defect.
Take your intake manifold off. You will find your rear knock sensor is swimming in water from the rain.
Replace the sensor and silicone the wire plug to the valley cover.....
Your car will run fine in the rain now...
Ruff in the rain? - your knocks are swimming in H2O
My car ran like **** in the rain.
I took the intake manifold off and found my rear knock sensor was swimming in rain water....
Replace the sensor, silicone the wire plug to the valley cover and your car will run fine again...
...Another GM defect bites the dust...
