Installing GMMG Tonight...Any Suggestions?
Any last minute suggestions before I install this? I know a lot of guys have had banging issues because the clamps weren't tight enough so I'll look out for that. Besides that though, is there anything else I should be aware of? I have all the tools I need and I'll be putting the car on jack stands to do the job.
Take your time and dont rush anything.....If you hear any hich pitch squeaks, then you need to adjust your heat sheild. Check under your car to see where you exhaust is rubbing your heat sheild ( located under your gas tank ) mark that spot, take the heat sheild off, and bend or reshape that spot.
Also check this thread out~~~~
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/236666-sagging-exhaust-tips-fix-pics-inside.html
Originally Posted by ulySSes
Polish it before you install it.
Only install problem I had was getting the tips lined up, even, and level...in fact, I never was able to get them perfect (but then I'm over-critical!)...the rear section is fully welded, so the tip placement is tough to fine-tune...be patient and you'll get them set up to your liking!
Have fun...
Have fun...
Have fun...
Have fun...
