18x10.5 z06 motorsports wheels..what size tire?
Old 12-26-2004, 05:53 PM
StangEaterSS's Avatar
Default 18x10.5 z06 motorsports wheels..what size tire?
I'm looking to put some 18x10.5 z06 motorsports wheels in the rear on my 98 C5 vette. what is the widest tire I can fit on this rim and will still fit on a 98 corvette. i was thinking they probably make some kind of tire like a 335/35/18 but would you need to modify anything to make that fit?
Old 12-26-2004, 06:30 PM
TooSlow02's Avatar
Michelin makes the Pilot Sport in a 335/30R18, but you need a 12" wide wheel to mount it. The stock size is 295/35R18 on Z06 Vettes, no rubbing. You can use a 315/30R18 tire, but it's about 0.60" shorter than the stock size, and will change the speedo slightly. Lingenfelter makes a mini-tub kit for C5s, letting you fit up to a 345/30R19, but you would need 19"x12" wheels.
Old 12-26-2004, 06:59 PM
skewba98z28's Avatar
Why 10.5's. I saw a 18/12 Z06 wheel somewhere on the net (sorry I can't remember where). I did see the link to the site on digitalcorvettes.com I was reading about them and the place said they would fit on a vette with no modifications required.
Old 12-26-2004, 07:12 PM
SMDLS1's Avatar
the 18x12 Zo6 wheels are on ebay under wheels and tires search 18x12
Old 12-26-2004, 09:06 PM
I found a deal on some 10.5" ones. so i'm just looking for a good tire for these. I'm sure an 18x12 is quite expensive compared to these set of 4 for $700.
Old 12-27-2004, 01:41 AM
Yeah $700 is pretty cheap and I know about trying to save money. I thought the same thing when I purchased my wheels. I got 9.5's all the way and I could kick my butt for not spending the extra money and getting a 10.5 in the rear.
Old 12-27-2004, 08:20 AM
Xsta Z 28's Avatar
295/35ZR18 anything else will require modifications.
Old 12-28-2004, 07:12 PM
SPANKY LS1's Avatar
I have 18x10.5" +58mm at all four corners, 275/35/18 front tires, 295/35/18 rear tires. sits and looks good.
Shawn
Old 12-28-2004, 07:35 PM
2MuchRiceMakesMeSick's Avatar
They make a mini tub kit for the vette. I think it allows you to run as large as a 335 on the back.
Old 12-28-2004, 09:02 PM
mini tubbing requires cutting the fender well out and bolting in the new lingenfelter tub kit. I'm not cutting up a nice C5. i just want some wide tires for a 10.5" wheel, that require NO modifications.
so the 295/35/18 seems to be what i'll go w/. so what brand tire should I get? I want best traction w/out useing a drag radial.
Old 12-28-2004, 10:36 PM
5POINT7's Avatar
Kumho's hook relatively well for street tires. But you're asking a lot for traction out of a street tire.
Old 12-29-2004, 12:42 AM
Well in your first post you mentioned a 335 tire on the back. I was just giving you your options. Im in the market for a vette and I have no trouble putting the mini tub kit in once i get it. I think a 335 on vettes look sweet ***
Quick Reply: 18x10.5 z06 motorsports wheels..what size tire?
