pulleys
pulleys
I know this has been asked a hundred times but the SEARCH function is fucked up.
Are underdrive and alternator pulley really worth any gains? Or should I waist my money on something else.
If you plan on doing a Cam soon just wait till you put the cam in to do it. I would say get the pulley. I can't tell you how much it helps cause I did Cam,Pulley, and Intake all at one time then Ported TB.
When you guys say you did the pulley mode, are you saying you did just the crank or crank and alternator together? Also aren't these pullies pretty expensive? I thought I read they were like 250 bucks, which seems like alot of money.
Check out this thread.......
https://ls1tech.com/forums/generation-iii-external-engine/276941-pulleys.html
march also makes a underdrive pulley which is fluid dampered this makes life easier on the bearings it is 25% same as the asp but it is heavier.i bought it for better bearing life and march says they are dyno proven 12.5 hp increase i paid 195.00 from summit
and i bought my belts for 36.00 they were the gates belts
Originally Posted by thebernsZ28
I don't care if I feel it, I just want to see the gains on a time slip.
Will it affect anything adversly in hot weather?
