pulleys
Old Mar 5, 2005 | 09:12 PM
thebernsZ28's Avatar
Default pulleys
I know this has been asked a hundred times but the SEARCH function is fucked up.
Are underdrive and alternator pulley really worth any gains? Or should I waist my money on something else.
Old Mar 5, 2005 | 09:41 PM
Ferocity02's Avatar
Yes they are worth it. They usually are good for about 10rwhp. Even if you don't feel any gain, you will for sure notice that the engine revs faster. With your mods, an underdrive pulley is a good next mod.
Old Mar 5, 2005 | 10:04 PM
Joker # 9's Avatar
I noticed the motor reving faster....I jump into another LS1 without a pulley and it feels like it takes forever to get to redline.
Old Mar 5, 2005 | 10:33 PM
I don't care if I feel it, I just want to see the gains on a time slip.
Will it affect anything adversly in hot weather?
Old Mar 6, 2005 | 02:58 AM
ZR2877's Avatar
If you plan on doing a Cam soon just wait till you put the cam in to do it. I would say get the pulley. I can't tell you how much it helps cause I did Cam,Pulley, and Intake all at one time then Ported TB.
Old Mar 6, 2005 | 03:38 AM
Judd's Avatar
I noticed more of a "seat of the pants" feel from my UD pulley than I did from my lid. Good mod that I would do again {can't say that about all my mods}.
Old Mar 6, 2005 | 03:59 AM
d james's Avatar
When you guys say you did the pulley mode, are you saying you did just the crank or crank and alternator together? Also aren't these pullies pretty expensive? I thought I read they were like 250 bucks, which seems like alot of money.
Old Mar 6, 2005 | 07:19 AM
Viper's Avatar
$250 for mods is nothing in the LS1 world.
Old Mar 6, 2005 | 07:50 AM
Ron78Z&01SS's Avatar
Check out this thread.......
https://ls1tech.com/forums/generation-iii-external-engine/276941-pulleys.html
Old Mar 6, 2005 | 12:38 PM
Judd's Avatar
I did only the crank pulley.
Old Mar 6, 2005 | 02:56 PM
Ok, looks like my next mod will be the crank and alt. pulley.
Thanks
Old Mar 6, 2005 | 04:11 PM
Ferocity02's Avatar
I will be selling my ASP Pulley soon since I am going FI, and I need to use the stocker
Old Mar 6, 2005 | 04:23 PM
bad0211secws6's Avatar
march also makes a underdrive pulley which is fluid dampered this makes life easier on the bearings it is 25% same as the asp but it is heavier.i bought it for better bearing life and march says they are dyno proven 12.5 hp increase i paid 195.00 from summit
and i bought my belts for 36.00 they were the gates belts
Old Mar 6, 2005 | 05:02 PM
How much?
Old Mar 6, 2005 | 09:54 PM
Ferocity02's Avatar
Originally Posted by thebernsZ28
How much?
Haha... somone already jumped on it. sorry
Old Mar 6, 2005 | 10:57 PM
o2haWK's Avatar
Well it will make go through your RPMs quicker which obviously makes your ET better. I bet if you put Aluminum flywheel, carbonfiber Driveshaft, and ASP pulley with some 4:11...you would go through your rpm's a HELL of alot faster which is what you want for 1/4 mile..
