Tranny Cooler Install Help
Old 04-25-2005, 09:21 AM
musicmaker1586's Avatar
Default Tranny Cooler Install Help
Just wondering if any of you guys have any pics on where you guys mount the cooler. I have not brought one yet but I want to know how big the space it to mount it then get the biggest one possible! How big are the coolers that you guys are running? If you can put the brand of cooler you have, how big it is gvm, and where you mounted it!
Thanks so much
Old 04-25-2005, 11:48 AM
Moderator
jimmyblue's Avatar
I don't have any pics. I mounted mine low and centered
on the A/C condenser / radiator stack. It was the biggest
Hayden that Pep Boys had on the rack. I routed the soft
lines through a little rectangular cutout that is by the
bottom corner of the radiator. I used slit pieces of vacuum
hose to keep the sheet metal edge from chafing the hose
for the cooler. I put my cooler in the hot line before the
radiator though most folks seem to go the other way.
If I were going to do it again I think I'd put it in the hollow
space between condenser and radiator. Though that would
rob effectiveness some, when the A/C is on.
Old 04-25-2005, 09:36 PM
I havent looked there wouldn't you want to put it close to the tranny? Hey look at this link I think this is what you are talking about: http://www.ws6transam.org/transcooler.html
Old 04-26-2005, 06:22 AM
GregWS6&z28's Avatar
installed B&M 24K on 2 different cars "Dope" style
Old 04-26-2005, 08:26 AM
Pontiacerator
RevGTO's Avatar
I used this product and method: https://ls1tech.com/forums/attachmen...achmentid=9785.
Old 04-26-2005, 11:23 AM
SmokingWS6's Avatar
Here's how I mounted mine. Word of advice, don't use the lines provided in the kit. They leaked after year. I got some replacement lines at Autozone and they seem to be a better hose.
Old 04-26-2005, 12:50 PM
cool thanks for the pics they really help! So basically I can get what ever size I want to? Does anybody have any tips on installing? Does it come with instructions?
Old 04-26-2005, 05:39 PM
Blacker's Avatar
Here ya go
http://www.bfranker.badz28.com/94z/trannycooler.htm
Old 04-26-2005, 09:42 PM
Damn now that is detailed!!!
Old 04-27-2005, 07:37 AM
dubrado's Avatar
Originally Posted by RevGTO
who makes that cooler?
Old 05-02-2005, 01:34 AM
FaSS Blac's Avatar
I run two Hayden coolers, stand alone, and it works great.
Old 05-02-2005, 08:14 AM
Pontiacerator
RevGTO's Avatar
Perma-cool makes it. You have to fab up the brackets yourself - Ironworker fabbed up a couple of trick brackets for me - to mount it.
Old 05-02-2005, 08:57 PM
mrr23's Avatar
http://www.stealthram.com/2000pontiacformula.html click transmission R&R and scroll to bottom.
