Possible to make '01 temp gauge work like '98?
Old 05-02-2005, 06:53 PM
98_1LE's Avatar
Default Possible to make '01 temp gauge work like '98?
Is it possible to make the temp gauge on my '01 Trans Am actually work?
Old 05-02-2005, 06:54 PM
Black02SS's Avatar
I don't believe so. It has been discussed before and I don't think anyone has came up with a way to do so. I had to installed a autometer water temp gauge so I have a real idea of the cars temp.
Old 05-02-2005, 07:55 PM
qwikz28's Avatar
so the temp gauge isnt right? it says cold at startup and 210 at running temps and goes up after i kill the engine. i thought this whole time it was right?
Old 05-02-2005, 08:27 PM
horist's Avatar
99+ cars have dummy gauges in them... they basically read cold, operating temp, too hot...
My car runs around 185* and it still reads 210 on the gauge cluster...
98s are the only year that have a real temp gauge...
Old 05-02-2005, 09:24 PM
qwikz28's Avatar
that sucks... at least it reads that much. i will at least be notified if my car is drastically overheating right?
Old 05-02-2005, 09:34 PM
jay_99z's Avatar
Yep, that's about all they're good for.
Old 05-02-2005, 09:51 PM
qwikz28's Avatar
eh, i guess thats good enough
Old 05-03-2005, 10:45 PM
TRex's Avatar
What is the output signal to the gauge ? Analog, digital ?
Old 05-03-2005, 10:55 PM
obZidian's Avatar
i dont know, bujt when scanning my gauges reads about al off. my temp is about 20-30 degrees lower than actual temp, an im a 98!!!
these gauges totally suck!!!
Old 05-03-2005, 11:02 PM
horist's Avatar
damn... didn't realize even "accurate" gauges were off heh
From my understanding... you'll actually see the temp gauge move on a 98 ... go from city to highway and it'll be noticable...
whereas w/99+ , the change is barely even noticable
Old 05-04-2005, 10:08 AM
luv2spd's Avatar
Yeah, I can watch my gauge rise if I'm sitting in traffic for awhile.
Old 05-04-2005, 10:30 AM
speedracer5532's Avatar
Could you put a 98 cluster in a 99 and later car or is it more involved than that?
Old 05-04-2005, 11:25 AM
horist's Avatar
^^^ the sensor is different and so is the way the PCM interprets it... would be 100x easier to just put an autometer gauge in
Old 05-04-2005, 11:32 AM
tim99ws6's Avatar
Where do you install the sending unit at for the water temp gauge?
