What is the most quiet dual valve spring?
Old 06-12-2005, 03:19 PM
14 Second Truck Club
Hemi Killer's Avatar
Default What is the most quiet dual valve spring?
-Crane
-Patriot
-PRC
-Manley
I have the 2002 LS6 springs right now on the 5.3 with the crane cam and it's noisy. Trying to avoid that on the LS1 swap.
Old 06-12-2005, 03:22 PM
zracer28's Avatar
I just fired up my F14 with Dual PRC spring kit and it wasn't too loud at all.
Old 06-12-2005, 03:53 PM
smask04C5's Avatar
cranes get my vote
Old 06-12-2005, 04:34 PM
Kurtomac's Avatar
its not your springs, its your slow *** ramp rate cam and stiff springs.....same car same springs had a comp 216 220 525 532 114 cam in it with 918s springs and valvetrain sounded like a commercial sewing machine swapped out for a 226 232 595 598 114 XER fast ramp cam, valve train is much quieter.....just deal with it, its not hurting anything
Old 06-13-2005, 04:48 AM
XTrooper's Avatar
As Kurtomac hinted at, it's not just the valve springs that create valvetrain noise. It's the whole of all your valvetrain components that determines how noisy it will or won't be. My valvetrain is significantly quieter since I swapped in a set of Crane roller rockers. FWIW, the ramp rates of my custom grind Cam Motion cam nearly equal those of the Comp XE-R lobes.
Old 06-13-2005, 05:57 PM
1FASTBIRD's Avatar
Manley get's mine vote
Old 06-14-2005, 12:44 AM
Torquem's Avatar
prc duals on my torquer and you can hear absolutely NOTHING. They make no noise whatsoever. Kinda freaky actually.
Old 06-14-2005, 12:46 AM
52172's Avatar
why isn't comp 921's in your list?
Old 06-14-2005, 12:50 AM
DONAIMIAN's Avatar
I agree, most of the noise is gona come from your cam choice and rockers. Mine is loisy as hell when the hood is up, but when the hood is closed I dont hear it, and when im in the car weather driving or sitting at a red light I dont hear it.
Old 06-14-2005, 01:55 AM
Restricted User
CAT3's Avatar
Mine sounds like a whole bunch of sewing machines putting a circus tent together, but thats the "stealth" part. Mustang guys think its about to blow.....then it does, blows their doors off! Agree on ramp rates, sometimes lifters, rockers and a lot I believe has to do with getting the right pushrod. So many ppl immediately go to 7.4", but not every cam and combo needs them.
Quick Reply: What is the most quiet dual valve spring?
