Doesn't HP Tuners have a compare function?
Can't seem to locate it if it's in there. Want to see the difference in 2 timing tables. I can compare them side by side, but that's too much info to digest. Want to lay one over the other and have it show me the difference for each cell. I used to be able to do this in LS1 EDIT.
Thanks for the help!
What do you mean by "compare"? If you copy one and paste it over over the other, you will see the differences. So long as you don't save, you can continue to reload and paste, thus switching between the two.
Originally Posted by Black02SS
When you finally get this feature to use Gary, you will know what we are talking about. The compare feature will tell you in a instant what is different between two different files and the fields that have been changed.
