Need help car blowing blue smoke.
Need some help figuring this one out. My car blowes blue smoke when I
Deexceleration" Im thinking it might be to thick of a oil,currently I use Royal Purple 10w-30. I also have full exaust with no cats, and still have egr, no tunning yet. I don't know weather it is bad valve gides, to thick of oil, or tunning. Please help me. Let me know what you think it might be, Thanks Everybody.
Thanks for the help, could the smoke be steam form the water in the exaust. The car does not sweat out of the exaust after installing the headers and Y. If it is blow-by should I just get a new block. Please help
watch the smoke...if its water vapor it will dissapate quickly (about 18" from exhaust pipe). shouldn't need a new block. If it is blow by it could be as simple as getting new piston rings. The valve guides would also be an easy fix but you would have to pull the top of the motor apart to see for sure what the problem is.
Originally Posted by calongo_SS
Do you have a catch can? Check and see if there is oil in the intake. This is the most common cause of oil consumtion on these cars.
As a Technician, a "rule of thumb" that we always follow is S.S.S. Start Simple Stupid. A lot of time people FREAK OUT, and think they need a new engine when something happens. ****No Offense**** A PCV is the easiest thing to check, also a commonly overlooked piece to be replaced. Who knows, it might be that easy. Replace the pcv, if that doesn't work, well everybody else outlined the needed diagnostic above. Good luck and keep us posted.
Hay Calongo_SS, where are you located in Corpus, Im from Corpus, too. PM me with a phone number so that maybe you can help me figure it out. I could use some help from fellow LS1 guy. You might know me, I use to hang out with you guys and race with everybody. Thanks for the help guys. Will let you know what it is when I find out...
Also might want to take off the oil cap while the car is runing at operating temp. I had 30 psi compression in cyl 5 and when I took my oil cap off smoke came out like a chemney. Needless to say piston ring was shot. Other people on here have had the same problem same symptoms. But like everyone said check the simple stuff first. Im like you always doom and gloom when it comes to the car im usually wrong but that time I wasnt
