JWIS Timing Chain
If you are trying to decide to go with the jwis or the ls2. Go with the ls2 there is not enough difference in most applications to justify the price. I'll look a little further into it and see if I can find something for you. I personally use a double roller. Not necassary but hey why not be double safe.
The new LS2 chain has a significantly different link that has an increased thickness over the old style link found on the LS1 and LS6.
Picture between stock and an ls2 chain.
Edit: linked pic because it's huge
http://temp.corvetteforum.net/c5/pew.../ls2_chain.jpg
That's all I could find. I can't find any pics of the jwis. But it is made by Katech.
You'd be fine with the ls2 chain unless you are planning on getting the TRex cam or bigger. Anything mid 230's and smaller you will be fine and proly even much bigger than that. I like to be safe though
