rockers and lifters....
Old 09-13-2005, 09:50 PM
SSdreamz's Avatar
Default rockers and lifters....
AFR heads, 232/234 112 lsa cam, full exhaust and LS6 intake, im thinking while i have it all apart, rocker arms and lifter should get yanked out in place for some newer ones. anyone have any suggestions on brands or stick with stock, etc......
Old 09-13-2005, 10:17 PM
bigdsz's Avatar
How many miles on the engine? If mileage is high, say 50,000 or so, use Comp 850 lifters. I just changed my liftersfor the first time at 78,000. Keep the OEM rockers.
Old 09-13-2005, 10:19 PM
redline2k's Avatar
Crane cams rockers and lifters
Old 09-13-2005, 11:48 PM
Nearly_Gone's Avatar
i am geting ready to change my heads to patriot and a comp cam (222/222 duration & .563 .563 Lift, 114 LSA) i was going to go ahead and put roller rockers, Comp pushrods and i was wanting to get new lifters, but i dont know ifi should. i am not too familiar with cams but i was talking with the tech at LS1speed and he siad for my application, thats what he would go with.
Old 09-14-2005, 07:09 AM
SSdreamz's Avatar
68,xxx miles
Old 09-14-2005, 08:55 AM
CATCH ME's Avatar
jesel shaft mounts...you'll never look back
Old 09-14-2005, 09:32 AM
bigdsz's Avatar
Just change the lifters, there are too many other places you can put your money and make a real HP difference.
Old 09-15-2005, 07:06 AM
SSdreamz's Avatar
just changing the lifters is what i was thinking too, but i wanted everyones opinion. my extra money could be spent on....MAS, etc, what you thing?
Old 09-15-2005, 08:14 AM
bigdsz's Avatar
When you have it apart, install a March under drive pulley, good for 8-10 hp. The reason for the March pulley over others is that it also is a harmonic balancer.
Old 09-15-2005, 08:26 AM
Ryan02SS's Avatar
Change the lifters and leave the stock rockers alone. It seems the incidents of needle bearings in the oil are pretty rare these days utilizing stock rockers. I went with the Yella Terra 1.7's and while they are a very nice piece I really didn't need them at the time and probably would not buy them again if I could do it over. I did notice the full roller setup did quiet down valvetrain noise quite a bit.
