replace speakers for cheap
Old 09-18-2005, 10:34 PM
SSRZ28's Avatar
Default replace speakers for cheap
my girl has a 02 V6 camaro. her rear sail panel speakers are blown. she has the monsoon speaker system.
what speakers are a direct fit for the front door, sail panel, and rear hatch. i tried to get her to just get the door and hatch and only use those off of a head unit but she wants all 8 changed. so im just gonna change all but the front tweaters and run them off of an aftermarket head unit.
Old 09-19-2005, 08:11 AM
shouldaboughttheZ's Avatar
read the sticky at the top of the forum.
oh hell, here ya go....
https://ls1tech.com/forums/wiring-stereo-electronics/303776-frequently-asked-questions.html
Old 09-19-2005, 01:49 PM
Ungrounded Moderator
WhiteBird00's Avatar
You'll have a tough time changing the door speakers but leaving the tweeters since they're coaxial.
Old 09-19-2005, 10:06 PM
SSRZ28's Avatar
i did read that sticky. didn't mention which speakers are a direct fit. but im goin to go with 4 alpine 170s 6.5" and an alpine HU
Old 09-19-2005, 10:45 PM
HiTechGent's Avatar
These are not necessarily cheap (~$180):
http://www.sounddomain.com/sku/IDSCX62
But they look to be the closest thing to a drop-in replacement for the sail panel speakers.
Old 09-20-2005, 09:00 AM
This is from the write up:
Fronts:
Alpine SPS-1005 Tweeters
Alpine SPS-170A 6 1/2's
These are a direct fit, but will have to do some electrical work to make them work with the monsoon system.
Are you going to replace the rear sail panel speakers with the SPS-170A's? If so, then it is going to sound like crap. Those are the subs in the monsoon system, and have a low pass crossover filtering them. You will need to replace them with a 6.5" sub.
Old 09-20-2005, 10:45 AM
zorrander's Avatar
I love these discussions about trying to get aftermarket items to work with the monsoon system. Just buy a new head unit and scrap the monsoon amp, wire the speakers to the new head unit... done. A decent head unit can be had for under $200 now... save yourself the headache!
Old 09-20-2005, 11:01 AM
thats all good, but people like me, the $200 HU is never good enough, I always want the better one.
Old 09-20-2005, 02:37 PM
HiTechGent's Avatar
Well, yes and no. Almost any 6.5" speaker will fit. But few 4 ohm speakers will sound good in place of stock 2 ohm speakers. The Alpine SPS-170A's seem to be the tried and true replacement for the door speakers. The original recommendations for the sail panels were Rockford RFP4406, which are no longer available. I have not seen anyone post about using the Alpines in the sails.
BTW: Camaro's don't need the separate tweeter, like the T/A's, in the door.
Old 09-20-2005, 03:10 PM
Originally Posted by HiTechGent
... BTW: Camaro's don't need the separate tweeter, like the T/A's, in the door.
Yep, that was my point - the Camaro has coaxially mounted tweeter and woofer in the doors. The problem is that they're not like the coax speakers you buy aftermarket. The factory speakers still have separate input terminals for the tweeter and woofer even though they aren't separate pieces so you're going to have to figure out how to connect four wires to the two terminals on the replacement speakers.
Old 09-20-2005, 03:26 PM
HiTechGent's Avatar
It's explained here how to do that.
https://ls1tech.com/forums/wiring-stereo-electronics/126979-those-wanting-only-upgrade-speakers-camaro-s-come-here.html
Old 09-20-2005, 07:17 PM
SSRZ28's Avatar
i am not using the monsoon anymore. running wires fromt he head unit to the new speakers. so will those 170s be fine for all four corners?
Old 09-20-2005, 09:53 PM
GPz1100's Avatar
Why run new wires? Why not just loop at the AMP connector the respective wires?
I did that when i was powering the aftermarker hatch speakers off the aftermarket HU.
Old 09-20-2005, 09:56 PM
SSRZ28's Avatar
becuase i never use factory wires when i install a stereo. always use high quality aftermarket wires. plus new wires will carry more current.
Old 09-20-2005, 10:23 PM
GPz1100's Avatar
SSR,
I agree with your statement to some extent. However, for 50-75 W rms, I think the factory wires are fine. Especially at normal volume levels. If you always crank things up, then after market 14 or 16ga wires would be better.
I ran my install with 12g only because I had it on hand already - 12ga to all 4 corners including the sub.
If I had to do it over, I'd just buy a 100' role of 14 ga and save the 12ga for something else..
Old 09-25-2005, 03:07 AM
SSRZ28's Avatar
where what what color wires go to which speakers?
i that easier than running new wires? just run all four wires to the amp in the back and connect them to the output wires of the amp?
Old 09-25-2005, 10:14 AM
00T\A's Avatar
I don't think the question has been answerd yet.
Are there any direct replacement rear sail speakers other than stock?
The Alpine SPS 1005 Tweeters (Direct Replacement)
The alpine SPS 170A for the door(Direct Replacement)
What about the Sail & Rear Hactch?
Does anybody have the Answer?
Old 09-25-2005, 10:26 AM
GPz1100's Avatar
I'm waiting for my translator to come online before replying - you should consider giving more care to your 'prose' if you want an accurate reply
However, wiring diagrams are readily available at this site;
http://www.houston-f-body.org/tech/monsoon/index.htm .
Old 09-25-2005, 10:27 AM
SSRZ28's Avatar
thanks 00TA. im hopeing the SPS 170A fit the sails too. so i can get four of those. aren't the sails a regular 6.5" although on crutchfields website, if you enter your car, that speaker doesn't come up as a direct replacment.
Old 09-25-2005, 10:37 AM
SSRZ28's Avatar
GPz. that site you posted says the sails are 6 inch?
and in my previous post, i was asking if it was easier to just run the aftermarket head unit wires to the monsoon amps output wires for the speakers.
