Has anyone ran more then 30 lbs of boost?
Old 09-22-2005, 07:56 PM
2000 Tran Zam's Avatar
Default Has anyone ran more then 30 lbs of boost?
Im just curious, i see people like harlan running like 25 or 27 lbs, i dont recall anyone running more then 30 psi.
If not, who holds the record for most psi sustained?
If so, what how much was it?
In addition to the above, what kind of numbers where they putting down(if recordable), what kind of turbo, and must be on ls based motor(c5r is ok too)
it can be supercharger or turbo
Old 09-22-2005, 11:17 PM
99SS-T's Avatar
I know there is a guy that runs 38-42 on his Firebird. I dont remember much more. I know he was holding a big record at the time. I think it was fastest 4th gen. He owns a tuning shop around here somewhere. Definatly sick!! GL
John
Old 09-22-2005, 11:25 PM
...with cheese.
Armageddon's Avatar
W2W runs a lot of boost. More than 30 I know of for sure. They are the current production block record holders.
Old 09-23-2005, 12:05 AM
V8_DSM_V8again's Avatar
You will need ARP head studs, copper head gasket with an oring job and a bore size that leaves enough room where cyls meet for sealing.
With a ICS titan SCE gasket you can skip the o-ring job.
On turbos those pushing the limits run in the 40# range.. Its a 4 LARGE ARP stud per cylinder rig just like a FI LSX engine..
Have the head and block machined properly to the right straightness and suface finish specs for a SCE gasket.. Then tq the studs using ARPs lube and proceedure to the letter.
Old 09-23-2005, 05:41 AM
smokinHawk's Avatar
Mike brown & steve turley has stated that they have ran over 30psi
i think wormboy and big rick have done there passes on "low boost" so they havent ran any high psi
hardcore has probably aproached close to 30psi if not over on there custom ls-similar-style block (more head bolts though)
Old 09-23-2005, 01:33 PM
Wnts2Go10O's Avatar
so when are we gonna see th efirst 500cid twin or quad turbo LSx with around 50psi?
Old 09-23-2005, 02:23 PM
NKAWTG...N
StoleIt's Avatar
id say ask marko, hes the one with the most experiance at close to 60psi
Old 09-23-2005, 03:11 PM
SSU Moderator
RyanJ's Avatar
how about every stock or near stock desiel on the road? the big dogs will push 75psi+
Old 09-23-2005, 05:07 PM
2001WS6Vert's Avatar
I think the APE shop car was also over 30. Where did that car go?
Old 09-23-2005, 06:00 PM
haha, lsx based motors, diesels dont count
Old 09-23-2005, 06:01 PM
Im not sure about the car, but i know APE went bye bye...
Old 09-23-2005, 06:17 PM
NA$TY-TA's Avatar
Last i heard he sold it to a family member for a $1 to try and save it when he went bankrupt.......
75psi in a diesl is weak sauce..... local guy here running over 100 and a 100 shot also...
Kyle
Old 09-23-2005, 06:33 PM
TrakDay's Avatar
Kyle
Yeah, there is a guy around Jax doing the same and running propaine or something crazy like that...
Old 09-23-2005, 07:36 PM
Trevor_00Ws6's Avatar
there was a procharged formula or z28 in GMHTP a while back that was pushing like 42 lbs of boost
Quick Reply: Has anyone ran more then 30 lbs of boost?
