New Crate 6.0, NO oil pressure.
Old 10-22-2005, 03:26 AM
MeanYellowZ's Avatar
Default New Crate 6.0, NO oil pressure.
Hey guys, just finally fired a brand new crate 6.0 in an S10. Engine has no oil pressure after extended cranking and 1 minute run time. 7 qts of oil in engine. Mechanical gauge, NO oil at head level from pushrods. Lots of oil in filter and coms out all over when you take the filter off. Is there some sort of plug or galley problem before the oil makes it to the mains but after it has been through the filter. BTW, the engine is very noisy (scary) when running with no oil pressure. Only been ran 10-15 secs at a time.
I did a search and didnt come up with the exact same problems so I'm posting. Any ideas???
Old 10-22-2005, 09:47 AM
Billiumss's Avatar
O ring on the oil pick up tube not seated correctly?
Old 10-22-2005, 12:32 PM
GoatChs's Avatar
Just had the o-ring problem this past week...fortunately, my engine is in a Yukon so pulling the pan was not too difficult.
Need to make sure the o-ring is fitted properly and the pick up is seated all the way in the pump. If the o-ring/pickup is good, swap the oil filter...there have been defective filters that have had the flow path blocked.
Old 10-22-2005, 12:48 PM
vtanju's Avatar
the oilpump has to be primed
Old 10-22-2005, 11:56 PM
ArcticZ28's Avatar
I would not keep running the engine until you find out the problem. If need be, pull the fuse to the fuel pump so the engine doesn't start when you're turning it over to check for oil pressure. Make sure the o-ring is seated properly and replacing the filter might not hurt either to rule out a cheap fix.
Old 10-23-2005, 12:31 AM
we're gonna try the filter before pulling the engine. We'll just continue to crank instead of running it We didnt run it any longer than necessary to determine that we really had a problem.
Pulling the engine again.....ugh
Old 10-23-2005, 01:02 AM
ArcticZ28's Avatar
Why are you going to be pulling the engine?
Old 10-23-2005, 01:40 AM
tbojbob's Avatar
There is a plug of sorts called an oil restrictor that goes into the back of the block, there have been some issues where new engines/short blocks have been shipped w/o them..........try a search on "oil restrictor".
Old 10-23-2005, 10:10 AM
SUX2BU's Avatar
yup. i think its called an oil galley plug.
Old 10-23-2005, 03:24 PM
will have to take the engine out to remove the pan to check for pickup tube problems.
I will look into the oil plug deal, haven't found much on it yet. I assume its not an easy thing to work with
Old 10-23-2005, 05:25 PM
GDM Z28's Avatar
if the oring wasnt sealing correctly would the filter even get oil to it?
Old 10-24-2005, 06:23 PM
UPDATE
Both the front and rear oil galley plugs ARE in the engine. Looks like it's coming out
Old 10-26-2005, 02:38 AM
mr2guru's Avatar
Looks like an off white dumbell with an o-ring on one end. It is the oil bypass valve.
https://ls1tech.com/forums/showthrea...oil+plug+white
I wouldn't think new blocks would ship with them installed.
Old 10-26-2005, 06:43 AM
jay_99z's Avatar
Is the pressure sending unit intact? Any chance it's indication only problem?
