425 rwhp?
Um, NO. you'll need more than bolt ons to get that much power to the ground. you could do it with a shot of nitrous and those mods, or with those heads and a huge cam with one kick *** tune and that might get you there
well im tryin to do it without doin anything really wild because parents wont let me have nitrous and it is goin to be driven daily with a little bit of WOT when im feelin the need
Originally Posted by HorsePowerKing
well whats it gonna take without nitrous or takin the engine apart and i want to come up to someone and race without hearin anything spool up......
ok, get the heads ported/polished... say stage 2 or so, and get at least a 224/224 cam probably slightly bigger and you will be close. You already have good exhaust, and 425 to the wheels is ABSOLUTELY doalbe on a stock shortblock with a good set of heads and cams... Will need a good tune though...
Just get a bigger cam. 23x/23x 112 / 114 cam with LS6 heads (even stock LS6 castings) will net you right around 420-425rwhp, with the stock 10-bolt. You're going to need a clutch, by the way.
You aren't going to get the torque number you want without more displacement, forced induction, or nitrous.
You might be able to get 390-400 rwhp with stock LS6 heads and the 2002+ LS6 cam and full bolt on's. That's still a big might.
With stock LS6 heads and a 224 cam you will probably go over 400 rwhp, and possibly over 400 rwtq.
no way that torque number is happening on stock cubes/naturally aspirated (a few heads and cam packages broke into the 430s). Most cars making 425 rwhp make 380-410 rwtq. The reason is because most of the hp comes at higher rpms when the hp is higher than the torque. However, the Z06 heads and cam with a tune MIGHT be enough for 11s. A bigger cam (and possibly heads) would make 11s only a matter of traction.
