425 rwhp?
Old 11-13-2005, 02:49 PM
TNMuscle's Avatar
Default 425 rwhp?
Would the mods in my signature be enough to get about 425rwhp and 430-450 rwtq???
TNMuscle is offline
Old 11-13-2005, 02:54 PM
sstony's Avatar
Um, NO. you'll need more than bolt ons to get that much power to the ground. you could do it with a shot of nitrous and those mods, or with those heads and a huge cam with one kick *** tune and that might get you there
sstony is offline
Old 11-13-2005, 02:58 PM
TNMuscle's Avatar
well im tryin to do it without doin anything really wild because parents wont let me have nitrous and it is goin to be driven daily with a little bit of WOT when im feelin the need
TNMuscle is offline
Old 11-13-2005, 02:59 PM
TNMuscle's Avatar
I forgot to include the tune consider that in there
TNMuscle is offline
Old 11-13-2005, 03:05 PM
Full-Force's Avatar
another um, no
Full-Force is offline
Old 11-13-2005, 03:07 PM
TNMuscle's Avatar
well whats it gonna take without nitrous
TNMuscle is offline
Old 11-13-2005, 03:08 PM
TNMuscle's Avatar
or takin the engine apart and i want to come up to someone and race without hearin anything spool up......
TNMuscle is offline
Old 11-13-2005, 03:14 PM
NviouSS's Avatar
a different cam would help, port/polish the heads
NviouSS is offline
Old 11-13-2005, 03:21 PM
TNMuscle's Avatar
ok anymore advice would help
TNMuscle is offline
Old 11-13-2005, 03:27 PM
LETHL_SS's Avatar
Originally Posted by HorsePowerKing
well whats it gonna take without nitrous or takin the engine apart and i want to come up to someone and race without hearin anything spool up......
The reality is that its not going to happen unless you spray or tear into the motor. No way around it.
LETHL_SS is offline
Old 11-13-2005, 03:30 PM
TNMuscle's Avatar
well LETHL_SS what have you done to yours and what would mine be about puttin out now with the setup in my sig with port\polish and tune
TNMuscle is offline
Old 11-13-2005, 03:31 PM
TNMuscle's Avatar
bump...
TNMuscle is offline
Old 11-13-2005, 03:37 PM
JEB99TA's Avatar
With the mods in my signature, I'm barely making 400 to the ground. Thru high-flow bullet cats and Borla exhaust/muffler. A4 w/ Yank SS3600.
JEB99TA is offline
Old 11-13-2005, 03:48 PM
natronathon's Avatar
ok, get the heads ported/polished... say stage 2 or so, and get at least a 224/224 cam probably slightly bigger and you will be close. You already have good exhaust, and 425 to the wheels is ABSOLUTELY doalbe on a stock shortblock with a good set of heads and cams... Will need a good tune though...
natronathon is offline
Old 11-13-2005, 03:56 PM
baldurann's Avatar
Just get a bigger cam. 23x/23x 112 / 114 cam with LS6 heads (even stock LS6 castings) will net you right around 420-425rwhp, with the stock 10-bolt. You're going to need a clutch, by the way.
baldurann is offline
Old 11-13-2005, 05:06 PM
JEB99TA's Avatar
Then you can replace your stock tranny, and rearend. That's too much horsepower for stock internals and driveline ... living on borrowed time. Put money into your foundation before you build your house.
JEB99TA is offline
Old 11-13-2005, 05:14 PM
BlueSix's Avatar
You aren't going to get the torque number you want without more displacement, forced induction, or nitrous.
You might be able to get 390-400 rwhp with stock LS6 heads and the 2002+ LS6 cam and full bolt on's. That's still a big might.
With stock LS6 heads and a 224 cam you will probably go over 400 rwhp, and possibly over 400 rwtq.
BlueSix is offline
Old 11-13-2005, 05:24 PM
TNMuscle's Avatar
what about removin cats too?
TNMuscle is offline
Old 11-13-2005, 05:32 PM
Moderator
davered00ss's Avatar
Ditch the Z06 cam. that is a 350rwhp package. Get a tr224 & afr heads.
davered00ss is offline
Old 11-13-2005, 05:46 PM
02 Camaro SS's Avatar
no way that torque number is happening on stock cubes/naturally aspirated (a few heads and cam packages broke into the 430s). Most cars making 425 rwhp make 380-410 rwtq. The reason is because most of the hp comes at higher rpms when the hp is higher than the torque. However, the Z06 heads and cam with a tune MIGHT be enough for 11s. A bigger cam (and possibly heads) would make 11s only a matter of traction.
02 Camaro SS is offline
Quick Reply: 425 rwhp?
