Installing converter without removing exhaust
Old 11-20-2005, 11:50 PM
vMaster0fPuppets's Avatar
Default Installing converter without removing exhaust
I need to install my new converter but have mmy exhaust we;ded at the Y pipe. Is it possible to install this without cutting the y-pipe
Old 11-21-2005, 12:03 PM
ponyeater01LS1's Avatar
why cut it just take it out?? i had to take the exhaust out from the headers back meaning y pipe and exhaust came out if u dont u will never have any room to get the tranny out
Old 11-21-2005, 01:39 PM
Blown SS's Avatar
I did it with the full exhaust in place , I have Mac headers though , Good Luck
Old 11-21-2005, 06:34 PM
Blacker's Avatar
I did my converter swap with the exhaust still installed.
Old 11-21-2005, 06:40 PM
phoenix's Avatar
i have to take my y pipe out in order to do it
Old 11-22-2005, 07:09 PM
meSSman02's Avatar
I would highly recomend it
Old 11-23-2005, 11:04 AM
Ouija's Avatar
As long as you can get the car high enough, you can usually get the trans out without having to remove the exhaust.
Removing the exhaust normally just makes it easier to get to the Bell-housing bolts and the E clips on the cooler lines.
The trick is to make sure you have about 2 feet of extensions so you can hit the bell-housing bolts on the top while being at the tail end of the transmission.
Old 11-23-2005, 11:48 AM
what he said ^^^^^^^^^^^^^^^
Old 11-24-2005, 12:46 AM
sweet man. I have those parts, so I'll use them.
Old 11-26-2005, 11:54 AM
Cheater's Avatar
just take your exaust off so you want hurt your 02 sensors
Old 11-26-2005, 01:08 PM
Cheater's Avatar
or your shift cableorspeed sensor.
Old 11-26-2005, 04:43 PM
How would I hurt them?
Old 11-27-2005, 12:09 AM
Ouija's Avatar
Some people aren't careful when dropping a tranny. They just put the jack under it and drop it without looking at all sides and you can catch the transmission on an o2 sensor or something else.
Remember a "wobble" socket is also a great thing for helping with those top bell housing bolts, o ryou can use an impact wrench swivel joint (that has only one swivel, instead of 3.)
Old 11-28-2005, 12:45 PM
chrs1313's Avatar
pulled the trans in my car with the stock exast still installed, dipstick bolt and top center bolt of bell housing we a pain in the *** to get back in, i am glad that i am doen with it.
