Drag Racing Tech
I searched: Is the upper PHB needed?
Old 01-02-2006, 10:24 AM
LS1TECH Sponsor
Steve Burger's Avatar
Default I searched: Is the upper PHB needed?
Search resulted in a yes it is VS. a no you don't need it.
Is there a real answer to this or is it that subjective?
Old 01-02-2006, 11:12 AM
GM Muscle's Avatar
I havn't run one for a season or so and my PHB mounting points are fine, but my car only cuts 1.40s. Some of the hard hitting guys have to renforce the PHB mounting points because they bend.
Old 01-02-2006, 02:35 PM
Gary Z's Avatar
The PHB brace is definitely needed on any street-driven car. Without it, the chassis end PHB mount will collapse.
Old 01-02-2006, 02:54 PM
Sweet Cheeks
Damage Inc.'s Avatar
Old 01-02-2006, 03:06 PM
Gimp98TNT's Avatar
Mine has been gone for 2 yrs. I have put 3-4k street miles on it in that time and ive had no problems.
Old 01-02-2006, 03:53 PM
badass 2002 z28's Avatar
it's not really needed...
Mine's been off for 3 years...no problems on the street or the track
Old 01-03-2006, 12:12 AM
Retired Street Racer
Matt D's Avatar
No problems here, and I cut 1.4x 60fts as well as drive it on the street.
Old 01-03-2006, 11:38 AM
Race your car!
JL ws-6's Avatar
Mine;s been off.. I'm not doing anything impressive at the track yet, but have put about 8K on the street with it off, no ill effects. I know nothing is bent either.. I took some measurments before I took it off, and have checked them once a eason since then, nothing has moved. If you are road racing the car.. then it's probably a good idea to leave it in.
Old 01-03-2006, 12:11 PM
kp
kp's Avatar
I put mine back on after noticing the paint cracking on the mount where its welded to the subframe so something is moving there. If you boxed it in it would be ok probably but I just put the upper back on siince its only a couple pounds and clears my exhaust fine..
Old 01-03-2006, 01:18 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I've gone 1.35 without mine, but if I could find one, I would put one back on the car.
Old 01-03-2006, 02:14 PM
Brains's Avatar
The biggest reason I would personally keep it, even on a 1/4 mile car, is if you get pretty far out of shape on a pass. If you put the car sideways in the lane, there's a whole lot of stress on that single frame point, trying to push the subframe rails together/apart -- not to mention the stress on the single mount point. By keeping the upper bar in there, you're tying together the L and R subframes and distributing that load.
Old 01-03-2006, 02:52 PM
LS1TECH Sponsor
K Thanks. Looks like I will keep it. At 5 lbs I will cut out something else.
Old 01-03-2006, 05:25 PM
LS1Tech Co-Founder
Down the track, you don't need it. Trust me, I have fixed a number of suspension issues on my car and it currently leaves straight and tracks straight and that UPB does not do anything at the track.
But you will notice it gone when taking street corners... car feels less tight.
Old 01-03-2006, 05:31 PM
LS1TECH Sponsor
Well the new setup is not gonna be too street friendly. Drivability is defined as getting from the trailer, down the track and back to the trailer without stalling.
Old 01-03-2006, 06:05 PM
Race your car!
JL ws-6's Avatar
Guess I'm putting mine back in now...
Now I gotta lose another 5 lbs.. I hate this diet I'm on already!
Old 01-04-2006, 01:33 PM
Motorboater
SilverGhost's Avatar
i have one or two up in my attic, one for sure. i might put it back on. i've had it off for 4 years with shitload of passes and plenty of street miles with no ill effects that i know of, but this has me thinking, i'm going to examine that area for any signs of stress before the spring and we'll see.
Old 01-04-2006, 02:25 PM
11SECSS's Avatar
if you have a cage in the car that might help a little if you take it out
