Where to mount MONDO bypass
Old 01-15-2006, 03:23 PM
Junior's Avatar
Default Where to mount MONDO bypass
I need some help guys, im about to put a D1-SC system on my car (1999 Trans am LS1) and im having a small problem, where to mount the MONDO bypass valve. I am running the twin intercoolers and not sure where to put it. Any info would be greatly appreciated. Thanks guys
Old 01-15-2006, 07:26 PM
frcefed98's Avatar
If you still have the twins, best place would be on the plenum. Damn thing is huge. Or if you can fit it right between the "y" on the pipe going to the intercoolers. As long as its before the MAF you're ok.
J
Old 01-16-2006, 08:19 PM
maddboost's Avatar
Are you using the regular Mondo bypass valve or the recirculating one? For a MAF car you need the recirculating one.
Old 01-16-2006, 08:28 PM
Spdmn75's Avatar
where can you get one of these?
Old 01-16-2006, 10:41 PM
10 & 11 Second Club
Caveman's Avatar
I thought if its before the MAF you can vent to atmosphere cause its not metered air yet.
Old 01-16-2006, 10:42 PM
10 & 11 Second Club
Caveman's Avatar
Vortech Engineering
Old 01-17-2006, 12:18 AM
andereck's Avatar
Mount before the MAF between the throttle body and intercoolers. Preferrably as close to the plenum as possible. (it has the most surface area)
Remember that your engine is now cruising on unfiltered air so try not to suck in the hoodliner material.
Old 01-17-2006, 09:01 AM
MstgKillr's Avatar
I thought you would want to place it after the head unit and before the intercoolers to prevent extra heat and stress on the intercoolers.
Old 01-20-2006, 09:52 PM
Gary98Z's Avatar
ttt
Anyone else have success with the twins and mondo?
Old 01-21-2006, 11:50 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
are you using that cam in your sig with the procharger? it's not going to work well with boost.
Old 01-22-2006, 11:33 AM
UnderPSI's Avatar
I had the twins and a Vortec Mondo before going with the front mount. I put the Bypass on the driver side before the plenum. I cut out a piece of hose and welded the mount on to a piece of pipe. It fit pretty nice on the driver side, I had the opening facing down and it wasn't recirculating. I never had any problems with it.
Old 01-22-2006, 01:10 PM
Gary98Z's Avatar
Cool. Thanks for the info. Happen to have any pics?
Old 01-22-2006, 02:39 PM
Junior's Avatar
Thanks, that is a pretty good idea. Will try it out myself.
Old 01-22-2006, 02:44 PM
Junior's Avatar
The car in my sig was my old car but i did use the procharger on it with that cam. To tell you the truth it wasnt that bad. My current car is a 99 Trans am and im going with a blower cam this time around
Quick Reply: Where to mount MONDO bypass
