squeakin door hinge
I think we are all plagued with the squeaking doors, mine tends to sag at times as well, and needs adjusted. I just spray it down with WD-40 and it's fine for a couple of months. Kinda one of those normal problems like the squeaky hatch you fix with Electrical Tape.
The best lubricant for door hinges is red spray grease.It goes in thin like an oil but then solidifies.The can's actually show a door on them..it's an application engineered door grease etc.(think berkebile 2+2 makes some as well as others)oil,s are to light under the weight and last minimally.Hope this helps.
