Jacking a lowered LS1
I'm new to this type of vehicle (I'm used to being around lifted trucks) and I'm still learning and I have a question; I'm thinking of getting a lowering kit (1") ... I'm guessing I won't have too much trouble with this set-up on the street but I am curious as to how much trouble it will be to jack it up. There isn't much room to put a jack under it as it is. What is the best type jack to use? (consider a roadside flat too)
Thanks for the help!
1" shouldnt be bad at all...the jack that you should have in your trunk will fit great....mines is dropped almost 2" and the jack will fit where it's supposed to.
Outstanding! ... I'm feeling a lot better about putting these springs on. A friend of mine was telling me about a set of staggered 2x12's .. so, they're 2" for the fiirst 3ft or so and end up at 6" total height.
Yikes! Not real anxious to see that stock jack in action in the dirt/grass ... kinda' like the 'fix-a-flat" idea ... hopefully I'd be able to make it to a parking lot.
Thanks for all the inputs ... I'm gonna' take some measurements and see what type of set-up I need to put together.
Cheers!
Cheers!
