procharger ???
Old 04-25-2006, 04:43 PM
t-1
t-1's Avatar
Default procharger ???
im trying to max out the d1 sc i have on the car now.
i currently have an 8 rib set up with stock tensioner and i am making 11ish lbs of boost. im going to switch to a riechard racing ultra grip pulley and probally one of their tensioner pulleys. the goal is max boost... isnt it always.
is it a good idea to try and max out the impeller speed, or is that even possible? or is it a better idea to set it up to reach the maximum boost that most people get as apposed to trying to max out the blower and just causing massive slippage?? i got more questions but ill wait for theese responses
Old 04-25-2006, 04:50 PM
brad8266's Avatar
Why dont you juse shoot for whatever Hp goal you have. Why do you want to max out the blower anyway??
Old 04-25-2006, 04:59 PM
t-1
t-1's Avatar
because im at 6600 ft of elevation and i am pretty sure that the blower will not make the power i want at this elevation . the car currently dynos 624 rwhp corrected, so un corrected its at like 515 rwhp actual. elevation is horrid
Old 04-25-2006, 06:15 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Why not go with the SDCE set up and their 3.4 pulley? That got me 11 pounds of boost with a P1. With a D1 that set up should be 13 pounds (at least).
Old 04-25-2006, 08:14 PM
7 Second Club
ty_ty13's Avatar
you need a bigger inlet hat... like a 4'' elbow and a bigger air filter...
Old 04-25-2006, 11:29 PM
t-1
t-1's Avatar
too much money and too much down time. plus i ve heard that when done right the ultragrip pulley works good. im already at 11 lbs. average of 10 lbs
Old 04-25-2006, 11:31 PM
t-1
t-1's Avatar
i would agree with that. the inlet hat is pathetic. is there a kit or just something i should make?
Old 04-26-2006, 04:57 AM
EPP
EPP's Avatar
We picked up two pounds of boost by removing the inlet hat and installing an aluminum 4" 90 degree elbow, some additional tubing, and a monster K&N air filter. Where we occasionally saw blower belt slippage at 14 psi on the stock ProCharger brackets, at 16 psi with the reduced inlet restriction we did not get an belt slippage.
Yesterday we were tuning in another T/A that we had built an iron block LQ9 engine for, and have a D-1SC on, we removed the stock inlet hat and filter assembly and picked up an extra 100 rwhp with no other changes. This was with a one inch larger crank blower pulley that we had made for us, which is turning the blower at 65,000 rpm. We are going to install a larger blower pulley today to reduce the blower rpm. Bob
Old 04-26-2006, 05:16 AM
wicked_95z's Avatar
Holy Crap...100 RWHP
Old 04-26-2006, 07:22 AM
If you are running a SC, money is not an issue. On the SDCE there is no down time. What you do is buy a J bracket from Tru Tech, send it to SDCE, have SDCE do thier magic on the bracket, and you put it on the same day you get the SDCE kit. FWIW thats what I did.
Old 05-03-2006, 01:41 PM
t-1
t-1's Avatar
thanks guys. ive seen 16 psi on this pulley setup when the belt is freshly vht'ed. so im going with the same size pulley just a ultragrip for approx 160 then make a better inlet housing, thanks for the help
Quick Reply: procharger ???
