exhaust problems
Old 05-03-2006, 10:15 AM
charles clark's Avatar
Default exhaust problems
has anyone had problems with pacesetters y-pipe mine is hitting the bottom of the floor
Old 05-03-2006, 10:20 AM
carrsls1_camaro's Avatar
Very common problem you may have to do the BFH mod. Or just move the exhaust around until it sits where you want it. Best of luck.
Old 05-03-2006, 11:26 AM
Scotty-Z's Avatar
Yup, do a search and you'll find that the majority of people have this problem with it. A search will also find you a couple ways to fix it.
Old 05-03-2006, 11:27 AM
LS69TA's Avatar
I think that's why alot of guys run the TSP y-pipe. It doesn't seem to have as many problems fitting correctly.
Old 05-07-2006, 07:53 PM
thanks for the help
Old 05-07-2006, 08:41 PM
'00_Z's Avatar
I'm having the same problem right now. I believe switching to the poly(?) motor mounts may help.
Old 05-07-2006, 09:10 PM
Derek_02's Avatar
I'm haveing the same problem. I put poly mounts in and after about 2 weeks the mounts seem to have "broken in" and its hitting again. I also can't seem to get it to stop leaking. I cant understand how they can make the headers fit like a glove but make such a shitty Y. I'll have to do a search about it but if anyone can give any advice it will be greatly appriciated because I'm really starting to get pissed off with this.
Derek
Old 05-07-2006, 09:36 PM
4mula's Avatar
heat up the y pipe and bend it alittle. thats what i did and no more knocking.
Old 05-07-2006, 09:38 PM
kpowr82's Avatar
poly trans mount will do the trick 9 out of 10 times.
