exhaust problems
Old May 3, 2006 | 10:15 AM
charles clark's Avatar
Default exhaust problems
has anyone had problems with pacesetters y-pipe mine is hitting the bottom of the floor
Old May 3, 2006 | 10:20 AM
carrsls1_camaro's Avatar
Very common problem you may have to do the BFH mod. Or just move the exhaust around until it sits where you want it. Best of luck.
Old May 3, 2006 | 11:26 AM
Scotty-Z's Avatar
Yup, do a search and you'll find that the majority of people have this problem with it. A search will also find you a couple ways to fix it.
Old May 3, 2006 | 11:27 AM
LS69TA's Avatar
I think that's why alot of guys run the TSP y-pipe. It doesn't seem to have as many problems fitting correctly.
Old May 7, 2006 | 07:53 PM
thanks for the help
Old May 7, 2006 | 08:41 PM
'00_Z's Avatar
I'm having the same problem right now. I believe switching to the poly(?) motor mounts may help.
Old May 7, 2006 | 09:10 PM
Derek_02's Avatar
I'm haveing the same problem. I put poly mounts in and after about 2 weeks the mounts seem to have "broken in" and its hitting again. I also can't seem to get it to stop leaking. I cant understand how they can make the headers fit like a glove but make such a shitty Y. I'll have to do a search about it but if anyone can give any advice it will be greatly appriciated because I'm really starting to get pissed off with this.
Derek
Old May 7, 2006 | 09:36 PM
4mula's Avatar
heat up the y pipe and bend it alittle. thats what i did and no more knocking.
Old May 7, 2006 | 09:38 PM
kpowr82's Avatar
poly trans mount will do the trick 9 out of 10 times.
