MAP sensor code?
MAP sensor code?
I did a H/C swap on my car and today i got it tuned. It was throwin a map sensor code. It pluged in and i dont think i damaged it while i had the intake off. I was wonderign if any of you guys can suggest what to look for that might be causeing a problem? thanks for the help
The only ones I know are:
P0107: MAP sensor circuit low voltage (manifold pressure is low or high vacuum)
P0108: MAP sensor circuit low voltage (manifold pressure is high or low vacuum)
That's what she said...
Originally Posted by 35thls1ss19
whats the best way to check for leaks? i will check my fues now. thanks alot
What we mostly meant by leaks is check the PCV system, brake booster, MAP sensor, or anything else that would let in un-metered air.
