Generation III External Engine - just got an ls6 intake, cleaning tips?
C.J.
05-21-2006, 06:49 PM
Ok well I just picked up an ls6 intake for a hell of a price. Only thing is that is alittle dirty and what not, so i cleaned up the outside real nice but I am not sure how dirty it is on the inside. What would be the best way to clean the inside of this intake?
brad8266
05-21-2006, 06:51 PM
Soap and water, carb cleaner, degreaser. Whatever.. Just clean it and let it dry out before install.
orangeapeel
05-21-2006, 07:00 PM
Spray it with any de-greaser or carb cleaner. let it sit and wipe it out.
C.J.
05-21-2006, 11:18 PM
even inside the manifold and up into the runners?
LS144
05-21-2006, 11:34 PM
spray it on the rag and wipe it out. How good of a deal did u get just curious im needing one too
dlandsvZ28
05-21-2006, 11:35 PM
Simple Green and water.
staringback05
05-22-2006, 01:50 AM
carb cleaner works great
Billiumss
05-22-2006, 06:47 AM
Liquid Dawn, hot water, scrub brush, toothbrush.
99Custom
05-22-2006, 09:06 AM
carb cleaner is great
C.J.
05-22-2006, 12:43 PM
so it is goign to be ok to run water through the inside of the intake?
C.J.
05-22-2006, 12:44 PM
a good deal as in $150 dollars with throttle body as well! :)
snake charmer
05-22-2006, 12:50 PM
Wow ! That is a pretty good deal .
ChocoTaco369
05-22-2006, 03:39 PM
i don't see why using water would be a problem AS LONG AS YOU LET IT SIT AND DRY! don't soak it, take it out and put it on, soak it overnight and let it dry for a few days until you're sure it's dry inside. you can speed up the process by taking a hairdryer and shooting the warm air inside the intake.
once it's nice and dry it'll be fine, just don't install til you're sure.
MrDude_1
05-22-2006, 03:46 PM
its essentially a big chunk of nylon plastic.
it wont react with any normal soaps, or solvents... and water doesnt harm it..
feel free to throw it in the bathtub, take a shower with it, or soak it in a bucket... :)
C.J.
05-22-2006, 04:30 PM
Ok what is with the foam pieces on the bottom? What are they for?
jmm98LS1
05-22-2006, 04:39 PM
I believe those are to keep air from flowing in the gap between the manifold and valley cover. A guy I know had his FAST intake whistle a little because it didn't have that foam.
