just got an ls6 intake, cleaning tips?
Old May 21, 2006 | 06:49 PM
C.J.'s Avatar
Default just got an ls6 intake, cleaning tips?
Ok well I just picked up an ls6 intake for a hell of a price. Only thing is that is alittle dirty and what not, so i cleaned up the outside real nice but I am not sure how dirty it is on the inside. What would be the best way to clean the inside of this intake?
Old May 21, 2006 | 06:51 PM
brad8266's Avatar
Soap and water, carb cleaner, degreaser. Whatever.. Just clean it and let it dry out before install.
Old May 21, 2006 | 07:00 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Spray it with any de-greaser or carb cleaner. let it sit and wipe it out.
Old May 21, 2006 | 11:18 PM
C.J.'s Avatar
even inside the manifold and up into the runners?
Old May 21, 2006 | 11:34 PM
LS144's Avatar
spray it on the rag and wipe it out. How good of a deal did u get just curious im needing one too
Old May 21, 2006 | 11:35 PM
dlandsvZ28's Avatar
Simple Green and water.
Old May 22, 2006 | 01:50 AM
staringback05's Avatar
carb cleaner works great
Old May 22, 2006 | 06:47 AM
Billiumss's Avatar
Liquid Dawn, hot water, scrub brush, toothbrush.
Old May 22, 2006 | 09:06 AM
99Custom's Avatar
carb cleaner is great
Old May 22, 2006 | 12:43 PM
C.J.'s Avatar
so it is goign to be ok to run water through the inside of the intake?
Old May 22, 2006 | 12:44 PM
C.J.'s Avatar
a good deal as in $150 dollars with throttle body as well!
Old May 22, 2006 | 12:50 PM
snake charmer's Avatar
Wow ! That is a pretty good deal .
Old May 22, 2006 | 03:39 PM
ChocoTaco369's Avatar
Tech Resident
i don't see why using water would be a problem AS LONG AS YOU LET IT SIT AND DRY! don't soak it, take it out and put it on, soak it overnight and let it dry for a few days until you're sure it's dry inside. you can speed up the process by taking a hairdryer and shooting the warm air inside the intake.
once it's nice and dry it'll be fine, just don't install til you're sure.
Old May 22, 2006 | 03:46 PM
MrDude_1's Avatar
its essentially a big chunk of nylon plastic.
it wont react with any normal soaps, or solvents... and water doesnt harm it..
feel free to throw it in the bathtub, take a shower with it, or soak it in a bucket...
Old May 22, 2006 | 04:30 PM
C.J.'s Avatar
Ok what is with the foam pieces on the bottom? What are they for?
Old May 22, 2006 | 04:39 PM
jmm98LS1's Avatar
I believe those are to keep air from flowing in the gap between the manifold and valley cover. A guy I know had his FAST intake whistle a little because it didn't have that foam.
