smoke
Originally Posted by vettenuts
Immediately after install or when you drive the car? There will be some smoke from the engine compartment and tailpipe immediately after you start.
Originally Posted by GuitsBoy
Is the car tuned? Are the valve seals on the heads new and installed properly?
Originally Posted by Bad30th
I'm betting head gasket(s) or bolts incorrect torque order/spec ?
Rob (Bad30th)
Rob (Bad30th)
Did you seal the intake bolts for the inake rockers?
Originally Posted by 1sickta
Don Lee install it for me and i will take it back to them on wed. hope fully the head is good so i don't have call TSP.
There has been a recent batch of TSP ported heads that have had reports of smoking due to some porting issues... Look around in this forum for other posts on TSP/Dart smoking issues. If it turns out to be the heads I'm confident TSP will get things squared away for you.
Rob (Bad30th)
Originally Posted by SlickVert
99% it is only the intake rocker bolts were not sealed.
Easy fix.
Bob
Easy fix.
Bob
btw i opened valve cover and i saw mount of oil there is that normal ?
