lock-up?
lock-up?
I used the search and found nothing.So here it is I just installed a f-13 took it for a test drive and could not seem to get the stall to lock-up.Is this a tranny problem,stall problem or is it because its not tuned?This is a 3500ssf stall,3:23gear old lock-up was 30 before the cam.thanks or any help.
The PCM is probably not allowing the TCC to lock up due to the cam and "misfires" it thinks is happening. Get it tuned and have them adjust the misfires codes and you should be good.
just for ***** and giggles try re-setting the pcm.
turn ignition on
remove pcm bat and pcm ign fuses in engine compartment
turn ignition off
wait a minute
put fuses back in and start the car
like stated it is probably misfires however. when my car does it i put it in neutral (even while driving) and turn the car off. then just re-start the car and put it back into drive, locks up perfectly. only usually does it after nitrous runs .
turn ignition on
turn ignition off
wait a minute
