help with crane valve springs
i am trying to get these valve springs in, the part number is 10308-1.
do i use the stock spring seats or just remove them and put the shim that came in the kit in its place?
the reason i ask is i removed the stock spring and the new shim would not slide over the seal on the valve, so i know i will have to remove the seal
i really need some help here so i can get this put back together.
thanks brad
thanks brad
so what did you have to machine to put the new seals in ?
the kit that i purchased just came with a shim for each spring would i have to buy more shims?
the shim that i am talking about is the one that is about half way up on the valve i think it is caled a umbrella seal.
i was told that this kit is a derect bolt on
thanks for the help
thanks for the help
thanks for the help
thanks for the help
