leaking oil
No, oil should not be IN the distributor. So if its coming from the cap your opti is fucked.
However, the oil is likely coming from the seal behind the distributor. The opti has a round protrusion that mates with the cam, this protrusion has a seal in the timing cover it seals to. Its common for that seal to wear out.
The distributor seal is IN the timing chain cover. Behind the distributor.
The dist. and water pump must be pulled to fix it.
Go get a dist seal, if you go to advance auto or autozone, you'll have to buy a complete gasket kit for the timing cover to get that seal.
