LS6 intake is finally done!!!! -PICS!-
Ok, now I know its not perfect. But my starting point really sucked and I put alot of work into getting it where it is now. The prep isnt perfect but I'm extremely happy with the colora nnd overall outcome!!
Enjoy! Questions and comments welcome!
Luna,
Considering what you had to start with, it looks pretty damn good. I will make one suggestion and that is to take some lacquer thinner and wipe
the paint out of the fuel injector holes. It is guaranteed that when you install your injectors that paint in there will chip off. One of two things happen:
1) paint chips get into your heads
2) the chips will "migrate" out onto the adjacent surfaces of the intake.
Neither one especially #1 is a good thing.
Soooooooo, was it worth all the effort??
Bryan
Parbreak
Bryan
Parbreak
Oh, one more thing regarding installation: make sure you torque the bolts to the right spec (7 ft-lbs or 84 in-lbs) and NO more. Otherwise the paint on the bolt posts will start to crinkle. I had to re-do my first intake because of this, talk about pissed!!
Bryan
parbreak
Bryan
parbreak
Originally Posted by parbreak
By the way, silver is one of the hardest colors to spray!!
Luna, that **** looks AWESOME! It looks a lot better than what I think I can do. Nice job, especially if this is your first time dealing with paint and bondo. Anxious to see the install pics. Good luck.
Originally Posted by B.W.
I'm interested in doing this, what exactly did you do for prep work? Kind of paint you used? It looks pretty good btw.
Sticky, Sticky!!:
https://ls1tech.com/forums/showpost....61&postcount=9
Bryan
parbreak
I did pretty much what parbreak's sticky said except after the primer I hit it with bondo spot glaze or something like that (in a red tube) to fill in all the huge nicks
and dents in the plastic. Sanded that down, hit it with adhesion promoter again, and hit it with primer again.
I can't wait to get it on!
Before and progress pictures can be found in this thread https://ls1tech.com/forums/appearance-detailing/558221-need-help-prepping-my-ls6-intake-paint.html
