Newbie is lost....help asap
Ok ive been reading on this forum like crazy because im gettin pacesetter long tubes and ory by the end of the week...the only thing im concerned about is what else am i going to have to by to get these things up and running. Ive herd so much about the bosch 13111's and everything else. So tell me will i have to buy the bosch 13111's, o2 sims, o2 extensions or ne thing else.
Thanks so much for the help!
ok. dont buy bosch anything. since everything will have easy access get new spark plugs (NGK's) and ac delco 02 sensors if you want but i would wait since the ceramic curring out has been reported to foul out the 02's. as far as 02 extensions and ****..you need some 24" extensions (2) and heres where you make the call. you can either buy 02 simms or you can have your car tuned. either dyno tuning (costly) or a mail order tune. the mail order tune will run you about 250 bucks but will tune your pcm for the ehaders and take out the rear 02's so it wont throw any codes.
hope this helps~
hope this helps~
if you are not getting the SES codes tuned out for the rear O2's, you will need O2 sims
if you go with the bosch 13111's, you will not need O2 extensions, otherwise you will need the O2 extensions and use your stock O2's...one 24" extension and one 12" extension
you are going to also need new AIR & EGR gaskets - i wouldn't try to reuse the existing ones
since i'll be in the same boat... any header gasket that is recommended/supported around here that seals well???
LOL I have O2 sims and programmed out... I could probably get rid of those... but then do you guys just leave the connectors hang?
Originally Posted by cha1nz1535
so if i dont want a tune i can just get o2 extensions and then get o2 sims...
OK. Reuse the stock gaskets, or buy new GM gaskets. DO NOT use the paper **** Pacesetter gives you. Go ahead and get o2 extensions, since the Pacesetter ones suck too. You don't NEED o2 sims, and you can usually get the rear o2s tuned out for cheaper than a pair of o2 sims anyway.
