Tb
Old 08-30-2006, 06:54 PM
blkbird's Avatar
Default Tb
Will a stock 2000 tb fit an 01? I know it might sound like a dumb question, but I need to know. Thanks
Old 08-30-2006, 07:46 PM
SSmoky01's Avatar
You know, that is a good question considering they are different intakes. LS1-LS6, Egr-no Egr. I wouldn't think it would matter though. Anyone know???
Old 08-30-2006, 07:53 PM
DSRCAM's Avatar
yea it would line up just right!
Old 08-30-2006, 07:56 PM
Tainted's Avatar
you should be fine. I dont think the AGR would really amtter and if it did you could jsut ditch it altogether
Old 08-30-2006, 08:02 PM
99huggercamaro's Avatar
it works
Old 08-30-2006, 08:26 PM
staringback05's Avatar
no they wont, if the 00 tb is like the 99....it wont, the actual cable slide on the side that opens and closes it...is larger on a 01 then on 98-00....my 99 cable would not close the 01 tb plate all the way, so i have to use my 99 tb instead....i found this out when i first put my ls6 manifold on
Old 08-30-2006, 08:34 PM
Tainted's Avatar
^^ you just gotta adjust it
Old 08-30-2006, 08:41 PM
hmm yea, i guess you could...IF your going from the 01 to the 00, but you cant if you from the 98-00 to the 01-02....cables to short
Old 08-30-2006, 09:39 PM
blkbird's Avatar
So, is it too much of a hassle to do???
Old 08-30-2006, 10:12 PM
the cable should be longer and theres a small black box on the cable length, youll need to pop off the little cap on it and adjust it accordingly.....just know if the throttle plate still wont close then you will have your answer...and the smallest opening in the tb will cause idle to be total crap
