what should i clean my heads off with...
Old 11-07-2006, 12:38 AM
pdd
pdd's Avatar
Default what should i clean my heads off with...
after i remove them from the block? they will be going back on, im just changing to thinner gaskits
Old 11-07-2006, 01:39 AM
Quickin's Avatar
Use one of those sanders that vibrate, after you take all the big **** off with a razor blade.
You might get lucky like I did, my head gaskets looked like they just came out of the package in one piece. They looked like two new ones all in one nice piece.
Old 11-07-2006, 01:59 AM
Krab's Avatar
Those green scotchbrite pads worked great for getting the mating surface of my heads clean. That along with some brake cleaner.
Old 11-07-2006, 03:28 AM
DaddySS's Avatar
You should also seriously consider having a machine shop true up the heads, a light pass ( afew thousandths) is inexpensive and good insurance.
Old 11-07-2006, 03:52 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Heads can be vatted.
Old 11-07-2006, 08:04 AM
slow trap's Avatar
that's what i did. i actually used the rougher burgundy colored ones but the green will work great also. on a side note i tried to use a vibrating sander to polish my valve covers and wound up just using sand paper and alot of elbow grease since the valve covers are so rough but i didn't try it on the heads.
Old 11-07-2006, 08:18 AM
purdueranger's Avatar
Wire wheel on a cordless drill did the trick on my valves. Also taking some degreaser and simple green worked for getting the heads to look new again.
Old 11-07-2006, 08:32 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just don't sand blast them....pretty much bottom line.
