dropped my turbo and down pipe off to get coated...
Old 11-12-2006, 11:31 PM
2000 Tran Zam's Avatar
Default dropped my turbo and down pipe off to get coated...
Couple of questions.
Should I have them coat both hot and cold side, or just hot?
If I dont coat the cold, should I get it polished for 60 bucks more? is it worth that?
My hot and cold side of the turbo are about 2 inches from the radiator.
I think its gonna cost me about 200 for everything, except the polishing.
Its supposed to be rated to 500+*C
Should this help with some spool time?
Could this help keep underhood temps down enough to help prevent cavataion from my fuel pump?
Old 11-12-2006, 11:41 PM
ABeasst's Avatar
500C is only about 1000F. Thats not much.
Old 11-12-2006, 11:43 PM
sorry, im not sure what the calculation was but it was like 2500 F
Old 11-12-2006, 11:53 PM
ABeasst's Avatar
then thats like 1370C
Old 11-12-2006, 11:57 PM
ABeasst's Avatar
http://www.webmath.com/cgi-bin/tconv...=tconvert.html
Old 11-12-2006, 11:58 PM
mahhddgtp's Avatar
Yeah. Took down my post because I was like... waitttt a minute...
Old 11-13-2006, 12:03 AM
THE_SUPRA's Avatar
did you know that hippos kill more people every year then elephants?
Old 11-13-2006, 12:04 AM
THE_SUPRA's Avatar
i dont know why i posted that. and you should deffinantly have the compressor polished...for general bling purposes
Old 11-13-2006, 12:07 AM
mahhddgtp's Avatar
Do you really want to listen to a Supra owner?
Old 11-13-2006, 12:35 AM
NKAWTG...N
StoleIt's Avatar
Well just by logics sake...looking only at the superficial details-
Would you rather listen to:
The owner of a car that comes factory turboed and is known for its stereotypical huge turbo lag due to a child sized thumper...
or
The owner of a car that comes naturally aspirated from the factory...is a domestic should there for be (stereotypically) supercharged.
Old 11-13-2006, 07:01 AM
smokinHawk's Avatar
i would get both the hot and cold side coated since they both run close to the radiator.
and yes it will reduce under hood temperatures.
Old 11-13-2006, 08:27 AM
FastKat's Avatar
I would probably get both the hot side and cold side coated, however I have heard the argument that you want lots of heat and pressure on the hot side and as little heat and pressure on the cold side as possible... coating the cold side might work against that.
Just thinking out loud...
Old 11-13-2006, 12:28 PM
Sawzall and Welder Mod
Whistler's Avatar
Coat the cold side after the intercooler, but not before. You want the heat in the pipes before the turbo, and out of the pipes after the turbo. After your intercooler however, the radiant heat from your engine compartment will be greater than the temperature inside the pipe, so coat it to help it from being heat-soaked. You should probably make some heat shields out of stainless anywhere the cold pipes go near anything hot.
Old 11-13-2006, 02:23 PM
bowtieman81's Avatar
The only worry I would have on coating the inside of the cold parts in what happens if the coating starts to come off? It will go into the intercooler and/or engine.
Old 11-13-2006, 02:35 PM
mahhddgtp's Avatar
This makes sense.
Old 11-13-2006, 04:01 PM
So just stick with the bling then correct?
also, 60 bucks for polishing is pretty cheap right?
Old 11-13-2006, 04:02 PM
He said it was gauranteed to not come off (I actually asked the same question).
Old 11-13-2006, 05:18 PM
I guess it should actually be ready tommorow night, I'll try to get some pics.
They said it was gonna be like 200 more bucks for polishing, so forget about that.
I'll take pics of the coated turbo when i get it.
Old 11-13-2006, 05:30 PM
V6 Bird's Avatar
its not going to make that big of a difference on cavitation..
im still waiting on pics of that fuel system.
Old 11-13-2006, 05:32 PM
Lol, sorry man, keep forgetting.
Ill make sure to do it tonight, john should be coming over anyways.
Quick Reply: dropped my turbo and down pipe off to get coated...
