lt1 clearanced oil pan
Clearancing it yourself isn't that hard. Just make sure you take into account the rod as it moves by the pan. I didn't "adjust" my pan enough and I had to pull the pan to make a few minor adjustments so the rod would stop brushing against the pan.
If you're considering using the stock pan, I think the amount of clearancing is also going to depend on your rod selection as well. My Lunati rods didn't require much clearancing on the pan.
Pictures here:
http://www.caspeed.com/gallery8/index2.html
Show clearancing for Eagle rods. Mine didn't require nearly that much.
Pictures here:
Originally Posted by sleeperMULLET
the canton pan doesn't need to be clearanced
