new wheels
new wheels
will putting new 17" wheels (stockers are 16") screw up the actual odometer readeing and the actal MPH? if is how do i go about calibrating the car to 17s?
lt1man was correct. a smaller sidewall with the bigger rims will have the same overall diameter as the stock rims with a bigger sidewall. you can use a tire calculator like the one here to see if the new combo will be any different and how much it will affect your speedo
Originally Posted by Brian2006
use a 40 sidewall tire and it'll be fine. Other than that it's nothing major
