install questions
install questions
putting a 6.0 ls1 into a 73 camaro, does anybody know where to get engine mounts and anywhere i can get headers. thanks for the help
hey man, try aplace calledstreet n performance wep www.hotrodlane.cc they proply got everything you need down to the custem oil pan that youl nneed. barnat
i used the brp setup without having to modify the oil pan. the closest fit i could find for headers was 02 camaro pacesetters. i've heard hooker makes a header andd mount combo, dont know anything about it though. more info over on nastyz28.com and pro-touring.com, but this sight has got the most info. joel
These are the adapter plates I'm using, but have not done a test fit yet. I'm told that these work without modifying the oilpan and you will have to notch the frame for the LS1 a/c compressor on the lower right like most of the replies above suggest.
http://www.carshopinc.com/
LS1GM Click to enlarge
LS1 LS6 CONVERSION MOTOR MOUNTS ADAPTER PLATES
CAR SHOP LS1GM
Price: $39.95
CAR SHOP LS1GM
Price: $39.95
