install questions
Old Jan 24, 2007 | 02:02 PM
sharp1's Avatar
Default install questions
putting a 6.0 ls1 into a 73 camaro, does anybody know where to get engine mounts and anywhere i can get headers. thanks for the help
Old Jan 25, 2007 | 04:11 AM
Samba242's Avatar
Probably get better results posting this in the Hybrids section on this board.... folks there have put LS motors into just about everything.....
Old Jan 25, 2007 | 07:44 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would contact Energy Suspension. They do lots of conversion sets.
Old Jan 25, 2007 | 07:53 AM
barnat's Avatar
hey man, try aplace calledstreet n performance wep www.hotrodlane.cc they proply got everything you need down to the custem oil pan that youl nneed. barnat
Old Jan 25, 2007 | 09:04 AM
sharp1's Avatar
cool, thanks for the info so far
Old Jan 25, 2007 | 10:18 AM
SHINER's Avatar
moving to the hybrid section to get you some more feedback!
Old Jan 25, 2007 | 10:26 AM
bczee's Avatar
Along with S&P, You can also try t56kit.com and BRPhotrod.com, Hooker also makes the Engine Adpater plates and headers.
Not many choices on Headers.. Hookers and Custom built are about it.
Old Jan 25, 2007 | 02:55 PM
Stu Cool's Avatar
Check out the Stickys at the top of the forum. Most of the questions you will might come up with have probably been asked and answered. Aslo try a search on Gen II swaps.
That's a great swap
Pat
Old Jan 25, 2007 | 03:15 PM
stealth71's Avatar
We need a check the sticky smiley.
Old Feb 1, 2007 | 08:50 AM
sharp1's Avatar
lots of helpful info in stickey.
Old Feb 1, 2007 | 09:16 AM
joelvette's Avatar
i used the brp setup without having to modify the oil pan. the closest fit i could find for headers was 02 camaro pacesetters. i've heard hooker makes a header andd mount combo, dont know anything about it though. more info over on nastyz28.com and pro-touring.com, but this sight has got the most info. joel
Old Feb 3, 2007 | 02:56 PM
ggriffin59's Avatar
These are the adapter plates I'm using, but have not done a test fit yet. I'm told that these work without modifying the oilpan and you will have to notch the frame for the LS1 a/c compressor on the lower right like most of the replies above suggest.
http://www.carshopinc.com/
LS1GM Click to enlarge
LS1 LS6 CONVERSION MOTOR MOUNTS ADAPTER PLATES
CAR SHOP LS1GM
Price: $39.95
