bolt on and rpm?
Old 03-08-2007, 06:12 PM
Nick-lt1's Avatar
Default bolt on and rpm?
How high do you guys spin your bolt on cars to?
Old 03-08-2007, 06:15 PM
Blk97WS6's Avatar
I shift at about 6k with my cam, but would never take it passed 6200. I used to shift at about 5800 with the stock cam and bolt-ons. Remember you cant take it to high because of the weak rod-bolts in the 98-00.
Old 03-08-2007, 06:19 PM
5_02ls1's Avatar
i set mine to shift at 6 k and ive turned my 98 to 6500 before the rod bolts arent as weak as most say they are
Old 03-08-2007, 06:25 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I shift at 6300 on mine...
Old 03-08-2007, 06:30 PM
98camaroLS1M6's Avatar
depends on where the car stops making power, I know a guy that made power with stock cam up to 6500 so he shifted there but that is a little much for stock ls1 springs. I'd say between 5800-6300, but stock rev limit is 6000 so you would have to up that if you would want to shift higher.
Old 03-08-2007, 06:55 PM
Nick-lt1's Avatar
i thought that the stock rev limiter is set at 6200 rpm?
Old 03-08-2007, 07:51 PM
dpw41285's Avatar
im shootin for 6600 and rev limiter at 6700 but well say what the dyno says the power stops...isnt that what really matters, otherwise i spin it to 9k
Old 03-08-2007, 08:00 PM
BriancWS6's Avatar
When I had just bolt-ons I set the shift-lite at 5900-6k, limiter stayed at the stock setting of 6200 which is plenty high enough for the stock camshaft.
Old 03-08-2007, 10:13 PM
MeentSS02's Avatar
Stock rev limiter is at 6200. I bumped mine up a little bit, and will probably bump it a little higher if I ever replace the valve springs.
Old 03-08-2007, 10:31 PM
Blk97WS6's Avatar
Is this with the stock rod-bolts? If so, and you have a 98-00 your crazy.
Old 03-08-2007, 10:33 PM
bowtierodder's Avatar
i dont think its crazy
Old 03-08-2007, 10:38 PM
sledneck687's Avatar
I dont think that he is crazy. I changed out my rod bolts for when i get a cam that way I can shift at 6800. on stock rodbolts id feel comfortabe going to 6400, 6500 at the max. right now i shift at about 6100, all i know if im damn close to the limiter. must be making power because i pulled a 13.07 with just a lid and catback.
Old 03-08-2007, 10:40 PM
Blk97WS6's Avatar
6700 seems very high to me. Check out the internal engine section, there have been many people who have had problems spinning that high on stock 98-00 bolts.
Old 03-08-2007, 10:57 PM
yeah, i know, thats why i switched mine out for the Katechs. Did it while the pan was off looking for my rocker arm bearings thats why i 64-65 on stock, and 68 on the on the new bolts. Although, some people around me have been spinning thier motors quite high. many around 6800-7k on stock bolts. And these are 98 cars. sorry to get off topic. id say put it on a dyno and see where it stops making power, then shift.
Old 03-08-2007, 11:02 PM
Blk97WS6's Avatar
Oh ok. Taking it that high with some Katechs is perfectly understandable
Old 03-08-2007, 11:08 PM
Mac 2002 SS's Avatar
Old 03-08-2007, 11:17 PM
That's what she said...
TheBlurLS1's Avatar
With boltons, you're not going to make any more power by spinning it much higher than stock, and you're risking the pushrods.
BTW - I spin my '98 to 6800 (cam'd car with good springs) with stock rod bolts, and have been doing it for about 19k miles, no problem......... yet....
Old 03-09-2007, 12:25 AM
Blk97WS6's Avatar
With a cam that makes power that high, and springs to handle the lift, then i understand why your doing it. Hopefully nothing bad will happen
And im not saying its a gurantee that anyone is going to throw a rod bolt, but i just wanted to point out that its a proven fact that the stock rod bolts are weak, and many people have figured that out the hard way. When all is said and done, get it on a dyno and see where you stop making power. If theres no need to take it up that high, then way gamble? and with a stock cam, theres no need to go above 6200.
Old 03-09-2007, 02:05 AM
chrs1313's Avatar
6100 seems to work pretty good for this auto
Old 03-09-2007, 06:49 PM
Nick-lt1's Avatar
How many miles are on your car? That makes me feel good about putting a cam in my car down the road!
